truck pukes!!
   / truck pukes!! #1
deerefan
Veteran Member
louisiana
1952 8N, 2005 JD 5103
Weird problem I'm having...I have a bone stock 97 F150 4x4 with the 4.6 V8 and automatic trans. The truck has about 140k miles on it. Under normal driving conditions, truck runs flawlessly. When I am pulling a trailer, which does not exceed 4000lbs loaded, I find the drivers side wheel well and frame coated in antifreeze. I traced the leak back to the radiator cap, which was original. I replaced it and the problem occured again. The truck never runs hot, always stays in normal temp range. My mechanic pressure tested the system and found no problems. I just replaced the bottom radiator hoses and will be replacing the top hose shortly. Any suggestions???
   / truck pukes!! #2
Check the radiator puke (purge) tank if it has one. It might be cracked. Also look at the heater core hoses.. The heater core is probably on the passenger side but the hoses may be run around the engine compartment a bit.
   / truck pukes!!
speaking of heater core...i had it replaced about 2 years ago but did not start having this problem until about 4 months ago. i'll check the heater core hoses but all the coolant is at the driver's front of the truck.
   / truck pukes!! #4
The tip off seems to be you are putting more load when you are pulling a trailer.. That is adding a little more load to the engine where it might be getting a little hotter. And yes them heater cores and hoses have caused me grief before.
   / truck pukes!! #5
One other thought. I bought a brand new 2004 F350 "built Ford tough" Super Duty and they used the cheapie squeeze-type radiator hose clamps instead of the ones that have a screw to tighten. I had leaks from them on two separate occasions where it was spewing coolant all over the place.
I took it back to the dealer (under warranty) and they fixed it by replacing the cheapies with screw-type clamps (but, of course, only the one that was leaking, not all of them). So I have a mixture of clamps on there now and carry a couple of spare screw clamps in the tool box. I'll change them all over when I get around to it.
Anyway, short story long, it looked like I had a bad problem from the amount of coolant that was coming out, but it turned out to be a very simple fix.
   / truck pukes!!
i used the screw type clamps on the bottom hoses, i still have the factory clamps on the top hose...i'll change them this weekend and see what happens
   / truck pukes!! #7
Coupla thoughts:
How much does the rear sag when pulling? Have you carried load in the bed that causes that much sag, and, if so, does the antifreeze appear? Wondering if it might be a truck attitude rather than temp issue.
You might ask about this on the Ford Truck Enthusiasts forum. Lotas great knowledge and people there.
Some on FTE have mentioned that some ford gauges (not sure if this is coolant or just trans temp) are driven by switches, not true analog sending units. If true, and your truck is one, it might be getting close to overheat, but not enough to swing your gauge to the "H" position.
   / truck pukes!!
i will try that site...i don't think the truck is overheating, i do not feel a real power loss...
   / truck pukes!!
i had one fellow suggest a bad head or head gasket, but if that was the case wouldn't it act up all the time, not just when pulling a trailer??
   / truck pukes!! #10
That is correct it would do it all the time.
Check the radiator and make sure it isn't cracked there where the cap goes since the cap is suppose to relieve pressure into the over flow tank and also draw it back into the radiator.
Check and make sure the pump is doing it's job also just for kicks.
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2006 International 9400i (A53472)
2006 International...
2011 Crown Victoria Sedan (A51694)
2011 Crown...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
19200 (A50324)
19200 (A50324)
BAUMA LIGHT TX 12 LOT NUMBER 240 (A53084)
BAUMA LIGHT TX 12...
