troybuilt horse tine question?
   / troybuilt horse tine question? #1
backwoodbill
Hello all!:
Well made my first blunder with my t.b.horse adjusted the belts cause they slipped every time I hit a root or glanced off of a submerged rock of hefty size well needless to say the torque after adjustment must have increased x3 coupled with the depth guage being set on the #4 slot third pass around the garden plot after two passes on#2 slot thought I could mow right through with no problems well you probably guessed I mowed through 2 almost new tines which raises the question any one ever weld them and ever have any sucess in them holding up? (note they bkoke at the 2nd. hole from the top) and I will have to redrill the holes to get them round cause to get good penetration its goin to run over into the holes and what type of welder did you use arc or mig? and what type of electrode did you use if you arc welded it? as it wont matter on the mig I only have .35 and .30 fluxcore wire I,am just not sure as I have never welded steel that hard or brittle as this as it broke similar to how cast iron breaks but a bit more jagged after this you can be sure I will only increase the depth one notch at a time and when I hit one of those rocks stop and hand dig them out boy will I be glad when I get all the big stuff out of the plot and put the manure to it then its fairly smooth sailing from there so sure will appreciate any info or advice as to if it can be done effectively sincerely pissed off and feelin stupid Bill!
   / troybuilt horse tine question? #3
I am thinking you have aftermarket tines on your Troy-Bilt tiller. I have run over ALL KINDS of nasty crap buried in customer's gardens and NEVER EVER busted a tine. Does each of your tine blades have 3 holes in it? If yes, it's aftermarket and although cheaper, not as good a quality.
2015 Nissan Pathfinder AWD SUV (A48082)
2015 Nissan...
2018 HINO 268 26FT BOX TRUCK (A51222)
2018 HINO 268 26FT...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A51039)
2017 Ford F-550...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
2008 Crown Victoria Sedan (A48082)
2008 Crown...
2020 Chevrolet Tahoe SUV (A48082)
2020 Chevrolet...
