troy built identification help
   / troy built identification help #1
bruce 1965
Springville Al
joon deere 445,john deere lt150,troy horse 1019
i have an older troy built tiller and am having problems with the serial number. I cleaned the area where it says serial number here but i am having no luck. I have included some photos. Thanks Bruce
   / troy built identification help #2
I have an old "horse" also and the s/n is hand stamped on the surface just below the top "cover" for the gearbox where is says tiller ser. number. Mine is a 6 digit#
   / troy built identification help #3
My Troy-Bilt is a "Bronco CRT" and is about 6 years old. The S/N is on a sticker on the right-forward portion of the tiller shield - on the outside - right behind the right tire.
   / troy built identification help #4
I dont see any photos:confused:
And what are you needing a serial # for?? Parts?? Is there other problems with it??
My guess would be if it SAYS serial #, but you see no number, it may have corroded away??? Is it stamped into metal? or is it one of those aluminum tags?
2015 Hyundai Elantra Sedan (A48082)
2015 Hyundai...
2014 Chevrolet Silverado 2500HD Knapheide Service Truck (A48081)
2014 Chevrolet...
John Deere HX15 Flex Wing Rotary Cutter (A50860)
John Deere HX15...
12 FLATBED W/ 300GAL WATER TANK (A50854)
12 FLATBED W/...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
