Troy Bilt pony tiller
   / Troy Bilt pony tiller #1
steviep
Milton NH
2001 JD 4300
I bought a troy bilt pony tiller this weekend for 25 dollars. It doesn't run yet. The engine was changed out at some time with a single shaft so no reverse.
The compresion is less then 50 so I am thinking it might be junk. It is a Briggs so changing it out can't be to hard if I can find one. It seems that HF doesn't have anymore of the $99 ones.
The numbers on the transmission are P53193 if any has more info for me.
   / Troy Bilt pony tiller #2
Troy-Bilt Pony Tiller Outdoor Power Equipment Repower from Small Engine Warehouse
Check those guys out for Pony engines. That is a steal even if it needs a new engine. Since you got such a great deal put a Kawasaki on .........wooooo woooooooo. Check the gear oil level by undoing the little square bolt on the side above the axle. If it is low fill with a straight viscocity gear oil. Mulit viscosity gear oil will corrode the bronze gears in a Pony. We don't use the reverse much here. Usually just pull it backwards. Mine is 20 years old and is about ready for some more tines. The engine still runs but when it konks out I'm going to get a Honda to go on it...at least that is the plan. Congrats on your deal!:thumbsup:
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
New Holland B95 Backhoe (A50490)
New Holland B95...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A50397)
1989 Freightliner...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
