Troy Bilt 5000/6250w Generator runs fine but trips circuit breaker
   / Troy Bilt 5000/6250w Generator runs fine but trips circuit breaker #1
SABEStef
PA
Kubota BX24
I have a Troy Bilt 5000w/6250w Generator with a B&S 1450 Series Engine that runs fine but trips the circuit breaker after approx 1-2 minutes even without a load on the generator; engine continues to run fine. When attempting to use generator power circuit breaker consistently trips. When attempting to trouble shoot the problem I removed (unplugged) all electrical loads from the generator and circuit breaker still trips continuously after approximately 1-2 minutes. The generator has approximately 24 hours of run since bought new approximately 3 years ago with no problems until now. Checked all ground connections and wiring with no visible evidence of problem areas. Any suggestions?
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
2014 RAM 1500 (A53422)
2019 Caterpillar DP35N 7,000lb Diesel Forklift (A54811)
2019 Caterpillar...
