Troy Bilt 25 CS weed eater Fuel lines
   / Troy Bilt 25 CS weed eater Fuel lines #1
bamaman01
Section Al
cub LT1042
I replaced the fuel lines on this weed eater due to ethenol gas eating out the lines. Once replaced, I can can get fuel to the primer bubble, but it will not start. Any thoughts on what Imay have done wrong?:)
Thanks in advance
   / Troy Bilt 25 CS weed eater Fuel lines #2
Fuel lines reversed on carb or primer. Junk in the internal screen of the carb.
   / Troy Bilt 25 CS weed eater Fuel lines #3
Did you put the fuel filter back on the gas line in the tank, and you could have the gas lines on backwards on the carb. Did you check the spark plug?
   / Troy Bilt 25 CS weed eater Fuel lines #4
Thanks in advance
If the gas ate the lines, there is a screen in the carb that will be gunked up with pieces of the old lines.
Makinex Electric Powered Hand Truck (A52377)
Makinex Electric...
2006 FORD F-150 PICKUP (A54313)
2006 FORD F-150...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
