tessiers
Platinum Member
- Joined
- Sep 22, 2007
- Messages
- 727
- Location
- Central Maine
- Tractor
- 05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
I have a Thomas T-83 skid steer I am having hydraulic troubles with. The system is a direct coupling from engine to 2 individual hydrostatic pumps then a gear pump on the front which operates the bucket and auxiliary. Each hydrostatic pump controls a drive motor, 1 for each side. Gear pump supplies the 3 spool valve for the bucket. All 3 use the same hydraulic reservoir.
Symptoms are:
Drives strong going straight, bucket is strong lifting and tilting, auxiliary hydraulics are strong.
Problem is when I try to steer left or right or operate the bucket while driving it loses most if not all power. Engine does not die out or bog down but hydraulics lose power. If I fiddle with the levers it will steer and drive, however the bucket will not operate while it is driving.
I think my problem is 1 or both of the hydrostatic pumps, the left seams weaker than the right. Anyone who knows what they are doing have an opinion? I have a shop that will tear them down and look at them but no one seams to want to test them because of bench contamination. If I knew how I would test them, I have a 3000 psi test gauge but not much else specialized.
Any insight would be greatly appreciated.
Jason
Symptoms are:
Jason
