Trouble Shooting Trailer Wiring?
/ Trouble Shooting Trailer Wiring? #1
ALMike
I've got a 16 ft bumber pull with breaks on one axle, and a set of rear brake / turn / running lights. It's got a 7 pin RV blade connector to my truck. I've got one 3 strand wire that runs to the electric brakes, and a two strand wire running to each of the rear brake / running / turn light units.
Nothing works though - I've got continuity between the ground plug and brake wire on the RV blade, but nothing else on the connector has continuity.
What should I look at / fix to clear this up? I assume that the rear lights are grounded to the frame, since they just have a two strand wire running to them, the frame is getting some corrosion on it.
Any tips on how I can use a multi meter to identify the potential source of my problem(s)?
/ Trouble Shooting Trailer Wiring? #2
Check the tow vehicle. If its a newer Ford/GM it has separate fuses and circuits for the trailer plug/vehicle lights.
Check all your grounds.
Chris
/ Trouble Shooting Trailer Wiring? #3
First thing to check, besides the fuses, is continuity between the connector's ground pin and the frame of the trailer. Same for the tow vehicle.
/ Trouble Shooting Trailer Wiring? #4
Trailer wiring..my nemisis:eek:
If nothing on the trailer is working, and you have power on the trailer side of the plug, then you likely have grounding issues.
I usually dont mess around with troubleshooting trailers, especially it it uses a frame ground. Its almost easier to rewire with new wire and run ground to all the lights then to spend hours chasing corrosion, loose connections and somebody elses work. If its your trailer, a rewire with soldered, heat shrinked connections and ground run to all lights, will save you headaches in the future.
My 2cents:D
/ Trouble Shooting Trailer Wiring? #5
The leads on multimeters won't reach from the connector at the front of the trailer to the taillights, for example. I get a long piece of wire I know is good and attach an alligator clip to each end. Then I can check using the multimeter. Sometimes helps to use the voltage part of the multimeter and make a drawing of which prongs on your vehicle are supposed to do what. Then start checking to see if the trailer is wired the same way.
Usual suspects are a ground wire that doesn't have good connection because of rust and bulb grounds that also have corrosion preventing a good connection. Then of course, there's always the problem that someone has wired the trailer to match their truck connectors in a way that doesn't match my vehicle.
Often, the trailer wiring is so bad that I just start over with new wiring. Cheaper than a ticket and much, much cheaper than an accident.
/ Trouble Shooting Trailer Wiring? #6
Chris
Dodge uses a different wiring pattern from the one used in the trailer wire coupling. Took mine to an RV maintenance shop and the fellow switched two wires in the trailer cable coupling, problem solved. Sorry, can't tell you wihich two wires he switched.
/ Trouble Shooting Trailer Wiring? #7
It is usually the positive wire that charges the trailer brake battery and the trailer brake actuating wire. Its the center pin and I believe the #2 pin on a 7 pin connector. Not sure at this time but have all the diagrams at the shop. To make things more interesting I have seen GM products with 7 pin connectors and no brake controller lock up trailer brakes as soon as its plugged in. Again, just 2 wires switched.
Chris
/ Trouble Shooting Trailer Wiring? #8
I would start out by disassembling the connector on the trailer end and see which wires go to what on the truck end (usually labeled on the truck end connector) they should be:
yellow wire - going to the left rear for stop and left turn
green wire - going to the right rear for stop and right turn
brown wire - going to both rear lights for running lights and also to the side markers
white wire - grounded to the trailer and for brakes
blue wire - power for brakes
/ Trouble Shooting Trailer Wiring? #9
I just got done completely rewiring my 16' trailer after a whole host of issues.
I cleaned up every ground with new connectors and never sieze greast.. I added a seperate ground cable fromt he frame that hooks to my trailer via quick connect.
I also had to replace the plug on my truck and trailer.. plug on the trailer got corrosion onthe back of it, and the plug on the truck had the blades spread and made bad contact.
If your trailer is a 6-pin setup and you use a 7to6 adapter.. some need a wire swappe dinternally for the brakes.
Also.. the brakes onthe trailer are really only 1 wire .. or 2 if you count ground.. it's just 'hot' to the electromagnet.
Your brake controller only really needs power and ground and brake power to the brakes to work using the panic button, plus the 4th wire fromt he brake switch to work automatically..
post back some more info.
soundguy
/ Trouble Shooting Trailer Wiring? #10
If you will take the plug apart and identify the wires, write down your findings on paper. First locate the ground pin, and see if it is grounded to the trailer. After that, use 12v battery and test lead and check each of the other pins. If you have help, they can tell you if the lights are working. If no help. use a mirror set up in back of the trailer and do some logical troubleshooting. some tinfoil and tape will make a reflector. Write all your findings on paper. Those 7 pin plugs are not all wired the same. When you are finished and everything is working, make a schematic of the trailers wiring diagram.
/ Trouble Shooting Trailer Wiring? #11
I like the tinfoil idea.. consider it stolen!.. I usually am stuck working alone.. even on 2-man jobs....
soundguy
/ Trouble Shooting Trailer Wiring? #12
I've felt like that about my trailer wiring before. The secret is to squeeze the trigger slowly, you'll get a clean shot every time.
/ Trouble Shooting Trailer Wiring? #13
My 2cents:D
+1
I finally just bought my first trailer that doesn't need to be re wired. On all my other trailers they used those blue quick connects.:mad: First thing I did was re run all the wire and solder the connections.
/ Trouble Shooting Trailer Wiring? #14
As far as trailer wiring goes, I have found out that there is no standard about which wires/color goes to which pin. There seems to be the U-Haul wiring diagram. There is the RV wiring diagram, and another one for commercial trailers. Also the gage of the wire changes for certain wires. As I said above, I have taken a multimeter and a battery and hooked things up, did my checks,and wrote down the results. Right now I am looking at three different wiring diagram. What I am going to do is trace out the wires on the trailer and match up wires with the correct pins. So if you borrow someones trailer, it might work, and might not. I have seen the testers for the 4 pins, but not the 6 or 7 pin. I am thinking about making one. What I have done in the past on the 4 pin, is to add bullet connectors behind the 4 pin, and if things are switched around on the pulling vehicle, then you can manipulate the wiring on the trailer to work.
42in. Hydraulic Auger Mini Skid Steer Attachment (A59228)
42in. Hydraulic...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2844 (A58376)
2844 (A58376)
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2017 Nissan Altima 4 door (A61306)
2017 Nissan Altima...
