trouble lifting MMM
   / trouble lifting MMM #1
Anonymous Poster
Epic Contributor
Sometimes it takes me three times to raise my deck fully. I have to push the lift handle back down and then back up each time the deck stops while being lifted. I have adjusted the lift speed knob and it has helped somewhat, but not totally. Any suggestions would be appreciated.
   / trouble lifting MMM #2
I had the same "problem". Turns out that I just had to lube the linkages and the lift rod that has the two springs on it. I used some of the Amsoil spray-on synthetic grease and all my problems went away.
2009 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
SET OF (3) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (3) ALCOA...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2010 L3V Electric cart (A51694)
2010 L3V Electric...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
