Posthole Digger trouble finding a replacement auger
   / trouble finding a replacement auger #1
KenKubota
Southern New England
Kubota B26
Hi there, I have a 3 pt post hole digger and would like to replace the auger. The trouble is, I don't know the brand of the unit and the auger seems to be an odd size. The round smooth drive shaft coming out of the gear box is 1 3/8 or 35 mm in diameter. It slides into the top end of the auger shaft that has an internal diameter to fit. Any idea where I can find an auger of this size? Thanks
   / trouble finding a replacement auger #2
Cant help with that exactly, but around my area, there are quite a few welding shops that will repair an old auger cheeper than buying a new one. The replace the screw tips and repair the rest. New teeth also.
   / trouble finding a replacement auger #4
If you strike out with the link from whistlepig, and it's worth the cost, a machine shop could make an adapter "sleve" to go to a std. 2" round that is comonly used on skid steer augers and there are many sizes available.
Thanks, I think I may try to have this auger repaired.
(1) 24' CORRAL PANELS W/ (1) 8' GATE (A51243)
(1) 24' CORRAL...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
**INOP** KOMATSU WA320-5L WHEEL LOADER (A51242)
**INOP** KOMATSU...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
