Trimmer harness
   / Trimmer harness #1
bmg88201
Quitman, Ar
JD X300
I want to get a harness for my trimmer. It gets a little heavy after a couple of hours plus I’m not 20 anymore. Also, I’m left handed so I was hoping I could get some recommendations on a comfortable harness to attach to my Echo trimmer. Any input would be appreciate.
   / Trimmer harness #2
If Echo doesn't make a harness, why not try Shindawa? I'm not left handed... If the harness doesn't suit you, you can cut it up and reverse it.
   / Trimmer harness #4
The ones Echo sends with there units are barbie doll sized and we throw them in the garbage. We switched to these Klein made tool totes straps which are much wider and better padded. We used harnesses at one time but will not go back to them.
Klein Tools 58889 Padded Adjustable Shoulder Strap, 37 to 55-Inch, for Klein Tools Tool Tote and 5003 Series​
   / Trimmer harness #5
my echo trimmer came with a harness that had a large plastic danger sign that is kinda woven in and lays flat on your back.
it shows a guy with a circle of safety that a visitor must avoid.
can't use the harness and the warning sign became a target.
2014 UTILITY 53X102 DRY VAN TRAILER (A43004)
2014 UTILITY...
New Pallet Forks (A39161)
New Pallet Forks...
Deere 490E Excavator (A40783)
Deere 490E...
2010 UTILITY 53X102 DRY VAN TRAILER (A43004)
2010 UTILITY...
2012 Suzuki SX4 Compact Sedan (A42744)
2012 Suzuki SX4...
AGT YSRT14 Stand On Mini Skid Steer (A44501)
AGT YSRT14 Stand...
