Triangle bracket for DK45SE Cab
   / Triangle bracket for DK45SE Cab #1
grm61
Platinum Member
Eastern Washington
2013 Kioti DK45SE HST Cab
So when the Dealer dropped off my Tractor he gave me a couple triangles.
I was finally going to bolt one on the other day, I assumed the spot would be the plate on the back of the windshield washer tank.
The triangle will bolt up, but the top link is in the way of the triangle when raised, it will clear if I turn the triangle on its side.
Do they make different sized triangles, or is there another bracket available? WTF, over?
   / Triangle bracket for DK45SE Cab #2
I have mine upside down but need to look into a bracket on the top of the cab back.
I must have a bigger triangle.
Mine is still in the way upside down, the only way it will clear is on its side...point facing the toplink.
   / Triangle bracket for DK45SE Cab #4
I bolted mine to the license plate holder on the rear and placed the license over the triangle.
   / Triangle bracket for DK45SE Cab #5
On the newer tractors (since early-mid 2013) there should be a 90 deg. bracket that attaches to the rear bracket on the top part of the cab where the sign will mount. Yes, before there really wasn't a place to mount the sign other than by the washer tank. It worked, you had to had special screws as those holes are threaded but when the third link came completely up it would bend the sign on one corner.
Not a big deal, the sign would normally just flex.
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
2015 Kia Sedona Van (A50324)
2015 Kia Sedona...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
INSPECTION (A51572)
INSPECTION (A51572)
