Trex for decking
   / Trex for decking #1
tglass
Platinum Member
3320 w/cab
Has anyone used Trex or an alternative to wood for decking? Wood doesn't hold up to the heat for me and even long term sealers don't last long. What about the frame? That is the first thing that starts giving on mine, and very hard to completly reseal.
   / Trex for decking #2
I just replaced my deck this year. The old one was likely 20+ years old and was unsafe (rotten) in a number of areas. I had to replace the whole thing. New pressure treated frame with Trex decking, couldn't afford the Trex railing so went with pressured treated wood there but will be putting a Trex cap on it.
Everything I could find out about Trex was positive but only time will tell. I am looking forward to having a deck floor with some colour on it, the old one was a mess. My only concern is how it will stand up to the cold weather, we can hit minus 40 during the winter.
   / Trex for decking
Probably going to replace the deck with Trex, but I'm not sure about the framing. I used pressure treated lumber and it was the first to give up. Thinking about steel, using steel used in some homes for the walls or pearling. Would cost quite a bit more, but I've already thrown money away with what I used initally.
   / Trex for decking #4
Composit wood seems to be the thing that is going good now.
   / Trex for decking #5
We built a new home last year and put Trex on for the deck. It was more expensive, but the builder said it would probably outlive all of us. After 1 year it still looks brand new.
   / Trex for decking #6
I had a 16 year old deck that I re-surfaced with trex three years ago (kept the old joists in place). So far the trex has done very well. Also, it is very easy to work with - cuts and nails beautifully.
   / Trex for decking #7
I want to do the same thing, my joists are 16" on center, did you have to add more joists? Will Trex span the 16"?
   / Trex for decking #8
Its been awhile since I've worked with it but, it would span 16"oc at 90 degrees to the joist. 12"oc was needed for diagonal installations.
   / Trex for decking #9
I'm not a big fan of Trex or any of the composit decking materials. It could just be me, but every time I've seen it, I see sagging and cracking in places. I have a way of finding flaws in things, though I never mention it to anybody, but if you look hard enough, you can find the flaws.
A really good example of Trex failure was at Yellowstone this past August. They put it down at the viewing area for Old Faithful. It's on 12 inch centers and has just about totally failed. I know it's used all day, everyday, but to me that just shows what will happen on a residential deck after a decade or so. The failures are that i's sagging some to real bad in places. It's cracked around the areas it's fastned to the joists underneath, and it flexes to different levels when walking on it.
For the money, I still like 5/4 PT decking. It shrinks like crazy, so you really need to set it out flat for at least a week before installing it.
Somebody on here mentioned a really good technique to preserve your PT joists. Put flashing paper over the edge before attaching yoru decking. You wont see it under the decking, but it will keep the moisture off of it when it rains. If you don't have flashing, cut roofing felt, or tar paper into 4 inch wide strips and staple to the top edge of the joists.
Good luck,
Eddie
   / Trex for decking #10
I used the Home Depot version of composite (Veranda I think) on my pool deck. I put it on 12" centers and used PT wood for framing. I kept the decking tight with no cracks and it will actually hold water a little (I have a slight run off). The worst thing I have seen is how hot it gets. When it gets to be 80 to 90 degrees outside the decking is so hot you can't stand on it with bare feet. I've had it for two years and still just like new without any sagging. It is the least expensive of the composite they offer and still cost me about $150 to do a 8' X 9' deck flooring and railing.
I have the Lowes version on my kid's play set (ramp to the slide and platform for the slide). I didn't care for it as well as it had ridges that the bees really like to build nests under it. This is probably 5 years old but just like new and no sagging or anything, but I always put it on 12" centers.
If I had it to do all over, I'd go the same route with composite, but next time I think I might try composite framing & railing too.
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
2014 Nissan NV200 Cargo Van (A53422)
2014 Nissan NV200...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
2004 PROCO 130BBL VACUUM (A53843)
2004 PROCO 130BBL...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
FAKE (A52472)
FAKE (A52472)
