Trenching for burying electrical cable
   / Trenching for burying electrical cable #1
rlee6
Central Florida
Allmand 8435 HST (TYM T330 HST)
Has anyone used a trencher before? I need to bury an electrical cable. I asked Home Depot Rental, where I am going to rent a trencher, but they said it would vary. I know it would vary with soil, depth, etc. Can anyone guestimate how long it would take to dig a trench that's 2.5' deep 100' long? I am in Florida and as far as I know soil is sandy to the depth. By the way, the are is cleared of all vegetation. Thanks.
   / Trenching for burying electrical cable #2
I would guess approximately 2 hours would cover it. Your soil is sandy and you can make good time. The most time consuming part is covering the ditch.
   / Trenching for burying electrical cable #3
Like you said, depends on soil, depth, etc. But is also depends on the trencher itself. When I put a water line in for the house I used a Ditch Witch. Went about 200' in about 4 hours. Then when I did the water line to the garage we rented a Vermeer about the same size as the DW and it took me at least 6 or 7 hours to go 100 ft. That Vermeer just wouldn't dig, the stored said it had new teeth, but I don't know how it could have. BTW, also used the Vermeer at my F-I-L that same weekend and it wouldn't dig there either.
   / Trenching for burying electrical cable #4
20-30 minutes to trench 100'. If you are using a self propelled trencher. I had no problems in sandy soil and no roots. Most of the walk behind rental jobs max out at 3 feet, so 2.5 will not go too fast due to the depth. You will also notice the UF feeder cable will be kind of springy. At least 10-3 is. Have a couple of pieces of a small brick or block to hold it down so it stays at the bottom of the trench when you backfill. A job like that overall would take me about 2 hours total as the previous person stated. Nowadays, I hand trench for distances up to 100 feet, then I wish I had a trencher about half way through. I look across the pasture, and think 100 feet is not that far away. I stupidly start digging by hand! I have done this three times now! I keep forgetting how far 100' is to dig by hand! /forums/images/graemlins/grin.gif
Joe
   / Trenching for burying electrical cable #5
Joe,
I had a 180' trench dug with a walk behind self propelled trencher and it took about 20-30 minutes to trench about 2.5 feet deep. My soil is 1 foot of top soil over sand. The hardest part was getting the trencher off of the trailer with out getting killed.
In the type of soil we have I think that the dig time would be less than one hour for an inexperienced person.
I also dig trenches by hand but have never had to dig a 100 footer. I usually take a few days doing the digging, dig when I get in the mood. Do not know why but my old body does not mind hand digging at least in the soil on my property.
Farwell
   / Trenching for burying electrical cable #6
Joe, i was laughing when i read about how far 100' feels. Living in PA we have dirt with rock, and then a bigger rock under that rock. i am almost done digging the trench, but i have gone through one landscapers pick, broke a handle on my shovel, and bent the long digging bar i have. Its been a nighmare, but there is nothing else short of a backhoe that will get through the rocks. I cant wait until i have that conduit in and get the sub panel put in.
later all and be glad your not diggin in pa.
forgeblast
   / Trenching for burying electrical cable #7
forgeblast,
sounds like you need one of these!
Or if that isn't enough you could bring in a bigger one:
/forums/images/graemlins/wink.gif
   / Trenching for burying electrical cable #10
I saw another set of pictures of that monster. Those pictures showed where that thing had scooped up a Cat D8 and it got wedged in the conveyor belt that carts the dirt back away from the digging teeth.
Unbelievable.
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A53426)
2019 HINO 195 16...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
2014 Kubota B2320 (A50123)
2014 Kubota B2320...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2019 RAM (A53422)
2019 RAM (A53422)
2018 Ford F-550 4x4 Cab and Chassis Truck (A51692)
2018 Ford F-550...
