Oil & Fuel Treated Fuel
   / Treated Fuel #1
Usta
Central Vermont
2008 Kubota BX2660
I have two 275 gallon tanks in the garage that I use for the furnace and have an electric fuel transfer pump on one to fuel my tractor. It is #2 heating fuel. I use nothing but home heating oil in my tractor.
(Please, Lets not rekindle the debate about difference between diesel and heating fuel)
My question is, can I treat the 275 gallons with PowerService without any problem with my warm air furnace burner?
   / Treated Fuel #2
I don't have the answer but great question! I've wondered the same thing but never asked.
   / Treated Fuel #3
I have two 275 gallon tanks and use #2 home heating fuel. One tank is in the basement, the other is outside. There is a gravity feed line with shutoff valves to feed the basement tank from the outside tank. I use PowerService in the outside tank as an option to help prevent gelling. I've had no problems running PS in my furnace fuel. In my area home heating fuel is #2 diesel with dye added.
   / Treated Fuel #4
No problems at all, may even be better as it is basically an additive.
2013 COACHMEN CATALINA TRAVEL TRAILER (A50854)
2013 COACHMEN...
DOOSAN G25 GENERATOR (A50854)
DOOSAN G25...
2015 Timpte Hopper Bottom (A50514)
2015 Timpte Hopper...
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
2018 PETERBILT 579 SLEEPER (A51222)
2018 PETERBILT 579...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
