Tread width for L3400
/ Tread width for L3400 #1
ToJo
AL
Kubota L3400 FEL
My L3400 has two adjustment positions for widening the tread or narrowing it . Since I have a loader, I think I should adjust it as wide as possible. The tread (center of tire to center of tire) now is about 47 inches. I can move the wheel out to the inside position and get about 4 more inches, making the tread about 51 inches. Is this preferable with a loader? Also, it will effect the other implements such as bush hog, road scraper, etc. Would two inches on each side make any significant difference anyway?
/ Tread width for L3400 #2
I have L3010. It has 44,48,52,54 inch spacing. I have it on 52. I think that wider is better for stability. I have not tried switching tires, but having proper tools and a helper might help. I will change to 44 for using a potato digger.
2008 Unverferth 220 Rolling Harrow (A63116)
2008 Unverferth...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
2020 Case TV370B Track Skid Steer (A64047)
2020 Case TV370B...
2016 Clemett Tri Axle End Dump Trailer (A64047)
2016 Clemett Tri...
2018 HINO 258A REEFER TRUCK (A63569)
2018 HINO 258A...
2015 New Holland TS6.110 Tractor with Alamo Boom Mower (A64047)
2015 New Holland...
