Travel Height Kubota 2410/60" MMM
   / Travel Height Kubota 2410/60" MMM #1
LGinIA
Iowa
JD X485 AWS,B2410,RTV900
Travel Height Kubota 2410/60\" MMM
This is my second season using the 60" MMM on my B2410. Other then placing pins in the front of the deck (when using rear pto attachments) is their an adjustment to have the front wheels off the ground when traveling. I may not remember correctly, but I think my deck would completely raise off the ground last year. Maybe I need to adjust the front link connection? Do the front wheels always ride on the ground when the deck is raised to it's highest level? Any user suggestions? Thanks
   / Travel Height Kubota 2410/60" MMM #2
Re: Travel Height Kubota 2410/60
I've got the same tractor and mower as you. In a perfect world, when you lift the deck to the full height, you'd be able to insert the pin that holds the mower up. More likely you'll be about 1/2 an inch short. Either way, that will lift the front wheels of the mower off the ground. I had to tighten up the linkage on the mower after a few months of use to get it to lift as high as it did initially.
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2012 Dodge Ram 5500 (A52377)
2012 Dodge Ram...
PALLET OF OIL COOLERS (A53843)
PALLET OF OIL...
2017 International DuraStar 4300 26FT Box Truck (A51692)
2017 International...
