Transmission shaft on a JD 420 - shot!!
   / Transmission shaft on a JD 420 - shot!! #1
JDKiotiboys3
Mooresville In.
Kioti LK3054,John Deere 420 L&G
Anyone know where to get a trans shaft cheaper than JDParts.com ? They want $550. the yoke from the drive shaft has worn the teeth on the trans shaft. And the drive shaft then in turn wobbles, Which in turn vibrates the whole tractor. Any suggestions? I originally thought it was the u joints but they are solid and in good shape.
Sent from my iPhone using TractorByNet
   / Transmission shaft on a JD 420 - shot!! #2
I would try a search in salvage yards or look for a parts machine.
   / Transmission shaft on a JD 420 - shot!! #3
I would search eBay. I think I saw one on there a couple days ago. Just make sure you know what trans you need. Not sure if they used diff models.in the 420.
I have a repair manual. Looks like it would be more difficult to change the shaft rather than the whole transmission !!
   / Transmission shaft on a JD 420 - shot!! #5
Once you have the rear fenders off everything is fairly straight forward. What part is worn out the drive shaft yoke or the input shaft in the trams.
I believe both. The yoke is loose on the trans shaft. I took the drive shaft off and they both look worn or a little chewed up. I know I will need a new yoke. And I know the trans shaft doesn't look right. Boy they sure made all those splines tiny back then
Oh I agree. But your also right about big bucks. You know what JD stands for, Jillion Dollars!!
Toro Mower (A50324)
Toro Mower (A50324)
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
