Transmission question
   / Transmission question #1
YanmarFever
Elite Member
Eating a melon..
Mahindra 5010C- Branson 4520r- 5520C- Yanmar FX235-D - Bad Boy rogue mower
Does anyone know if a transmission from a YM1500-D 4x4 fit a 1500 2wheel drive.:confused:
Im trying to help out a guy in Florida with this trans, but I dont know if it will fit his 2wd machine, all I have are 4x4s
Thank You, Ernie
   / Transmission question #2
Red or Green ? on Aarons site, the case seems to be the same but there is a different designation for some of the gears.
Bruce
They are both red, one is a 4x4 and the other is a 2 wd
Im still wondering if the 4x4 will work on the 2wd ?
Ernie
   / Transmission question #4
From what I gather from my 1500/1500D parts manual, the 4WD transmission will bolt in. The only gear differences are those for the front drive. The only possible fit problem might be with the 4WD lever, which could be simply cut off. If the drive gears to the front drive box don't hang too low, the cover plate from the original transmission can be used in place of that box. You could pull that box off your transmission to see if that is possible.
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2018 GENIE...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
PALLET OF SCAFFOLDING (APPROX. 18 PC) (A52706)
PALLET OF...
2025 K1119 UNUSED Metal Carport (A53117)
2025 K1119 UNUSED...
2015 Ford Focus (A51694)
2015 Ford Focus...
