transmission problems
   / transmission problems #1
gld
midway ga
jd 185
My John Deere 185 mows great until the tranny gets hot and then it will not move forward or backwards
   / transmission problems #2
I see you have a Sunstrand brand transmission, hopefully you can get it serviced. Since the mower is about 25 years old it is probably due for a transmission rebuild. The tolerance on the internal parts needs to be very close to work and with age and use the internal parts have worn to the point that the fluid is bypassing when hot and thin (lower viscosity). Hope it is a rebuildable component for your tractor, keep us posted on what you find out.
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55301)
2006 Magnolia Dry...
Toro Mower (A50324)
Toro Mower (A50324)
2006 STERLING L7500 DUMP TRUCK (A51406)
2006 STERLING...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
UNUSED EINGP MSC2030F 20' X 30' ALL-STEEL CARPORT (A54757)
UNUSED EINGP...
