timebak
Bronze Member
- Joined
- Feb 4, 2011
- Messages
- 65
- Tractor
- RK37SC & John Deere 2030
I have a 2010 LS R4020 with only 78 hours on it. It has had ALL scheduled maintenance and checks performed on it. About 4 weeks ago, I drove it about 6 miles, into town to have a small amount of work done on the FEL mounting bracket. It drove and shifted perfectly, as it always has. When I went to pick it up, the shifter was stuck and will not move out of whatever gear it is stuck in (I think it's stuck in 2nd gear). The range selector works perfectly and the F-N-R shuttle shifter works perfectly. The clutch adjustment is correct and working properly. It is not stuck in 4WD. The rear differential lock is not engaged. The brakes are not stuck. But the shift lever will not move and it won't even shift into neutral (except on the range selector and the F-N-R shuttle lever). I even took the seat off to see if there was something jamming the shift linkage rod and not allowing it to move.
I have not removed the shifter from the transmission to see if I can see anything in the transmission that might be stuck.
The guys at the machine shop claim that it worked just fine when they moved it in and then out of their shop.
I've called the dealer and they have no suggestions beyond what I've already checked and tried.
Does anyone here have any experience with this, or any suggestions of what to check?
