Transmission Oil Light Won't Go Off
   / Transmission Oil Light Won't Go Off #1
EmpireTractor2012
NY
New Holland TN75
I have a tractor where the transmission oil light came on. We have changed the oil pressure switch and the light hasn't gone off. I've been told that the wires have been checked for any pinching as well and nothing was wrong with them. We aren't sure what to check next. The customer, as well as ourselves, would appreciate the help.
   / Transmission Oil Light Won't Go Off #2
Maybe post make, model, and tranny, and help will appear.
Jim
   / Transmission Oil Light Won't Go Off #3
Does the light come on with voltage or without? In other words is the switch in the sensor normally open or closed? If it comes on with voltage does it go out with the switch not in the circuit? I have seen switches bad right from the box.
I would also check the wires myself. If I had a dime for every time someone said they checked something and didn't or didn't do it right, I could retire.
You say customer? Are you a dealer? Can't you check with the "factory" support?
2014 VOLVO EC220 DL EXCAVATOR (A51406)
2014 VOLVO EC220...
2007 VOLVO VHD64 TRI AXLE DUMP TRUCK (A53426)
2007 VOLVO VHD64...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
20" Sea Container (A47384)
20" Sea Container...
2019 TAKEUCHI TB290 EXCAVATOR (A51246)
2019 TAKEUCHI...
