Oil & Fuel Transmission oil for Mahindra 5500 4WD
   / Transmission oil for Mahindra 5500 4WD #1
RJFCO
I have a 2003 Mahindra 5500 4WD. I have been trying to find out what transmission oil to use. The owners manual specifies 80wt for my climate. The dealer's say use universal tractor fluid. Even the fluids recommended in the owners manual conflict, and are not close to 80wt. I can hear the gears in my transmission turning at idle in neutral (could be normal), and I'm thinking the oil may be a little light. Anybody have an answer, or is it that important?
Roy
   / Transmission oil for Mahindra 5500 4WD #2
UTF fluids are have a additive package designed to be used as a gear lubricant in common sump tractors. Personally as a lubricants consultant I feel if you have a seperate resivour for the transmission gear oil then that is what I would use, a gear oil. You will find many tractor manuals that recommend either UTF or a 80W and some a 80W/90 gear oil. I get the feeling they often list UTF as one option because it keeps inventory simple for tractors with seperate sumps.
   / Transmission oil for Mahindra 5500 4WD #3
I would run the 80w90 if I were you. Mahindra started recomending the UTF as it seemed to cut down on the transmission whining. I for one don't feel that the whining hurts a thing other than some people think it is annoying.
2012 Dodge Charger Sedan (A51694)
2012 Dodge Charger...
2011 Case 3020 30ft Flex Draper Head WITH TRAILER (A53472)
2011 Case 3020...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2019 KOMATSU WA380-8 WHEEL LOADER (A51246)
2019 KOMATSU...
