Oil & Fuel Transmission Oil Changes
   / Transmission Oil Changes #1
micman32
Millersburg, Ohio
Yanmar 221/Cub Cadet XT2
I have been reading some post about changing the hydro oil in the tranny. My manuel doesn't have a change interval listed. It does say change the filter every 100 hours. I just changed my filter the other day. I am guessing I had 120+ hours on it. The oil looked good and I just added about a quart to top it off. After changing filters it seems like I have a little more speed. My son even noticed it. I would say the filter is doing it's job and after so long it just needs replaced.
Michael
   / Transmission Oil Changes #2
I think the oil in the unit may be a 'for life' oil but we'll see. If Cub doesn't list a change interval then I think they feel confident it is good for life. But obviously if you do something to make the oil get overly hot that is something to cause a reason to change it out
   / Transmission Oil Changes #3
This topic seems to come up at least once a year. I did a lot of research into it, and concluded that you can survive either way. Change it if it makes you feel good, or if performance is sluggish and a filter change doesn't resolve it. Otherwise just stick with what the manual says.
   / Transmission Oil Changes #4
...I did a lot of research into it, and concluded that you can survive either way. Change it if it makes you feel good...
I hear that. As far as I know, the 2K series manual has never mentioned changing the ~6qts of trans oil. However, it's always spec'd a transmission filter change after the first 10hrs, after the first 50hrs, then every 100hrs after that. Many of us who have done trans oil changes have noted some gray, cloudiness to some of the oil as it's draining out the first time or two you change this oil. Is it really needed? Under certain usage I think it is. (stored outside, washing unit with water, not running it up to temp to name a few)
Joel
I know my oil has been changed twice. I usually have my unit serviced by the dealer. I know that changing the oil and filter in the tranny was part of the service that was performed. The last couple of years I have been servicing it myself.
I am impressed with the transmission on the 2500 series. I have never had to add oil to it. I check it and it's always on the mark.
Michael
   / Transmission Oil Changes #6
Hi,I recentlly purchased a used (329 hr.) 95? CC 1440 Hydro trans.The owners manual states trans oil and filter change needed at 100 hrs. I'd like to make sure maintenance is updated since I don't know the tractors history.I'm starting to go through it to prepare to use as a mower/cart puller this year.The trans oil part # that I have 737-3025 doesn't seem to be available.I have seen synthetic CC hydro oil.Is this an updated type that will work or should I keep looking for the "old type" for this application? More questions to follow.Thanks,Dave the newbie
   / Transmission Oil Changes #7
The older Hydros used "Hy-Tran" oil which should be readily available at any Cub dealer. The newer ones use synthetic but it is really expensive - like $40/gallon. I wouldn't mix the two.
Bob B.
   / Transmission Oil Changes #8
Thank you for the reply.One of the few times in life it's going to be cheaper for me.Works out the other way for me most of the time....
   / Transmission Oil Changes #9
At your cub dealer, Hy-tran is called "Hydraulic Transmission fluid". Hy-trans is the name for it at a Case IH dealer.
AJ
   / Transmission Oil Changes #10
Picked it up today.8 Quarts/$50.Better than $80.Used the difference to purchase the filters.Thanks,Dave
2019 FORD F450 TOW TRUCK (A51222)
2019 FORD F450 TOW...
2018 RoGator 1100C (A51039)
2018 RoGator 1100C...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
ASSET DESCRIPTIONS & CONDITION (A51219)
ASSET DESCRIPTIONS...
2005 INTERNATIONAL DURASTAR 4300 (INOPERABLE) (A50854)
2005 INTERNATIONAL...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
