Transmission oil change in Ferris IS700Z mower
   / Transmission oil change in Ferris IS700Z mower #1
mgarner
There is an old thread about this project but one thing I cannot find is a good solution for the problem removing the air vent plugs in the top of the transmission pumps. If anyone has any help on this please let me know.
   / Transmission oil change in Ferris IS700Z mower #3
I changed mine without much ado. Yes you fill, run and add to get fluid visible in the reservoir. Then run for a couple of minutes and start working the levers back and forth till you purge the air out of the system....just takes a few minutes. Then check for maybe half an inch of visible fluid when the unit hasn't been run for awhile...overnight. I found syn. 20w-50 at wallyworld, may have been their house brand but I have no problems with their house brand oils...they work in my equipment. I do use Rot. T6 full syn in my red tractors.
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
New/Unused 7ft 35 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 35...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
2015 Ram 3500 enclosed service truck (A52377)
2015 Ram 3500...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
