Transmission / HydroStat Problem?
   / Transmission / HydroStat Problem? #1
Flip221
When pulling my CC2544 out of the garage today, I noticed a "clicking" noise when travelling forward. The click does not happen when going backwards. The sound seems to be coming from the rear right side of the tractor.
Also, I noticed that the tractor rolls forward and backward without having the transmission lever pulled out. You can hear the gears moving when it rolls with or without the lever pulled out.
I have 8 hours on the tractor. Any ideas or suggestions?
Thanks,
Kirt /forums/images/graemlins/confused.gif
Thanks,
   / Transmission / HydroStat Problem? #3
My 2544 wont roll easily, but can be pushed without the bypass engaged. Pulling the bypass doesn't really make it any easier to push. /forums/images/graemlins/confused.gif Never did. /forums/images/graemlins/mad.gif I also had some clicking from the right rear axle seal when I first used it this season. I pulled the wheel, cleaned and rubbed some silicone grease onto the axle seal. Noise is gone. I'm still kinda p'd about the hydro bypass deal. The cheezy lever/spring does actuate the button on the bottom of the hydro, but nothing seems to happen. I should take it in, but it would be tough to take the downtime right now.
Joel
   / Transmission / HydroStat Problem? #4
Joel
Thanks for the feedback. So where exactly is this seal you mentioned greasing?
Has anyone had any luck with the transmission lever?
   / Transmission / HydroStat Problem? #7
The axle seals are pressed into the cast iron axle housing right where the steel drive axle(s) protrude from the transaxle.
Joel
   / Transmission / HydroStat Problem? #8
Joel
CIERZO ELECTRIC AIR COMPRESSOR (A51248)
CIERZO ELECTRIC...
New Holland LX865 Skidsteer (A51573)
New Holland LX865...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2014 Jeep Grand Cherokee SUV (A51694)
2014 Jeep Grand...
City of Buckhannon - Power Curber 5700 (A52384)
City of Buckhannon...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
