Transmission/hydraulic oil for a MF 1260 tractor
   / Transmission/hydraulic oil for a MF 1260 tractor #1
Donald56
I am planning on changing the transmission/hydraulic oil for my MF 1260 tractor. The owners manual recomends Permatran III, which is very expensive, or SAE 80 GL4. The local oil company does not have the fore mentioned SAE oil but does have SAE80/90 GL5. Would this substitute oil be okay for my tractor.
Thanks,
Donald56
   / Transmission/hydraulic oil for a MF 1260 tractor #2
PRODUCT DESCRIPTION
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil is an “all weather” Universal Tractor Transmission Oil (UTTO) engineered to meet the tough demands of heavy-duty, hydraulic-powered farm and commercial equipment. Its unique formulation of synthetic base stocks and additives effectively reduces wear, resists heat, protects against rust and extends fluid and equipment service life. Synthetic Tractor Hydraulic/Transmission Oil is recommended for extended oil drains based on oil analysis.
Excellent Protection in Temperature Extremes
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil operates over a wide range of temperatures. It has a high viscosity index to maintain its lubricity at high operating temperatures, and it flows at temperatures as low as -47°F (-44°C) for improved equipment operation and wear protection at low temperatures. Synthetic Tractor Hydraulic/Transmission Oil exceeds the most demanding “all weather” specifications of both Ford New Holland FNHA-2-C-200 & 2-C-201 and John Deere J20C & J20D, eliminating the need for seasonal oil changes.
Smooth Brake Operation
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil is formulated with durable friction modifier additives that effectively suppress wet brake chatter. Unlike conventional oils that can break down and cause vibration, AMSOIL Synthetic Tractor Hydraulic/Transmission Oil provides continuous frictional stability for long-term smooth brake operation.
Feature: Multi-Viscosity
Benefits: Excellent cold and hot weather protection, no seasonal change outs
Feature: Universal Applications
Benefits: Inventory consolidation, no misapplications
Feature: Stable Friction Modifier Additives
Benefits: Correct and decisive multi-disc/clutch operation, excellent control over brake chatter, smooth operation, extended oil and equipment life
Feature: Anti-Foam Additives
Benefits: Rapid air release, cooler operation, smooth brake operation, control over fade and spongy hydraulic response
Feature: Oxidation Inhibitors
Benefits: Excellent resistance to oil degradation at high temperatures, extended lubricant and equipment life
Feature: Seal and Hose Conditioners
Benefits: Compatible with all seal materials, seal and hose flexibility, positive seal seating, reduced oil leaking, extended seal and hose life, fewer blown hoses
Feature: Superior Anti-Wear Additives
Benefits: Scoring and gear wear protection under all load conditions, extended equipment life even under severe conditions, increased pump and valve life, may be used in final drives calling for a UTTO
APPLICATIONS
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil is Recommended for equipment combinations of transmissions, hydraulic systems, final drives, power take-off systems and wet brakes operating in "all weather" hot and cold temperatures, including, but not limited to, the following:
* Farm tractors and equipment
* Fork lift trucks
* Pavement rollers
* Off road equipment:
o Loaders
o Backhoes
o Bulldozers
o Tractors
o Logging equipment
* Ditchers
* Concrete formers
* Lawn tractor hydrostatic transmissions
* Golf course mower hydrostatic systems
* 4x4 ATV models with wet brake differentials
PERFORMANCE DATA
AMSOIL Synthetic Tractor Hydraulic/Transmission Oil is recommended for applications that require any of the listed specifications:
* AGCO/Duetz-Allis/Allis-Chalmers
Power Fluid 821 XL, 257541, 246634
* Allison - C-4, C-3, C-2
* Case Corp. J.I. Case & IH
MS-1207 (Hy-Tran® Plus), MS-1210 (TCH Fluid JIC145), MS-1230 (Poclain Equip-high pressure systems), B-6, MS-1206 (PTF), MS-1205 (TFD-II), MS-1204 (TFD), JIC-185, JIC-144, JIC-143, B-5
* Blearus
* Caterpillar - TO-2
* Clark - TA 12, TA 18, HR 500, HR 600
* Dresser CED - Trans/Hyd Fluid
* Hesston Fiat - Oilofiat Tutela Multi-F, AF-87
* John Deere - J20C, J20D (Winter grade), J20A/B, J14B, JD 303, J21A
* Kubota - UDT
* Landini - Tractor II Hyd. Fluid
* Leyland
* Massey-Ferguson - M-1141 (Permatran® III), M-1135, M1143, M1129-A, M-1127-A/B, M-1110
* New Idea Power Units
* New Holland Ford - M2C134-A/B/C/D, FNHA-2-C-201.00, FNHA-2-C-200.00 (Winter grade), M2C86-B, M2C53-A, M2C41-B, M2C48-C
* Oliver - Q-1802 Type 55
* Steiger - Hyd/Trans SEMS 17001
* Sundstrand - Hydrostatic Transmission Fluid
* Valmet
* Versatile - M2C134-D FNHA-2-C-201.00, Spec 24M, Spec 23M
* White Farm (Oliver) - Q-1826, Q-1802, Q-1766B, Q-1722, Q-1705
* Yanmar
   / Transmission/hydraulic oil for a MF 1260 tractor #3
I would hold out and find an oil that lists your oils ( either one) as a equivalent replacement.
For instance.. Generic UTF at walmart or TSC is listed as a repalcement for M2C134d.. a CNH utf oil.. etc.
I'd check around for specs..
Soundguy
   / Transmission/hydraulic oil for a MF 1260 tractor #4
The Amsoil hydraulic fluid would be real good if you cannot find the MF Permatran III product.
   / Transmission/hydraulic oil for a MF 1260 tractor #5
I am sure that Amsoil has a good produce that will work, but it will be more expensive that Permatran III. I don't know which transmission you have but put the oil that should be in it and you won't have problems. I have seen to many tractors with hydraulic problems because of cheap oil or types of oil that shouldn't have been in them to begin with. Get the Permatran and all will be well.
   / Transmission/hydraulic oil for a MF 1260 tractor #6
Is that the correct rating for your tractor. Thats waht was listed for the amsoil.
   / Transmission/hydraulic oil for a MF 1260 tractor #7
Permatran III is correct for his MF1260.
<font color="blue"> The owners manual recomends Permatran III, which is very expensive </font>
Amsoil is a lot more expensive than Permatran.
2021 Ford F250 4X4 Service Truck (A52377)
2021 Ford F250 4X4...
2015 Chevrolet Tahoe SUV (A51694)
2015 Chevrolet...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
Adams 5 ton Fertilizer Buggy / Wagon (A53472)
Adams 5 ton...
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR9EH765325 (A51572)
2014 International...
