Transmission/Hydraulic Fluid
   / Transmission/Hydraulic Fluid #1
smithleej
The transmission (manual) and hydraulics on my tractor share the same sump pump. What type oil should I use? I assume there is some generic fluid for this application, but I am not sure exactly what it is? Thanks.
   / Transmission/Hydraulic Fluid #2
What kind of tractor is it?
Whats the manual call for?
There are universal tractor fluids but they may or may not be ok depending on your type of tractor.
Owners and repair manuals may seem expensive but will pay for them self many times over.
With make and model I am sure someone can point you in the right direction for fluids.
Its a Daedong L3503-D (now owned by Kioti). The manual was converted from Korean, so its hard to interpret. Its call for Daedong TF65; Mobil 423; Yokong Torque Fluid 56; Korea Shell Donaz TD, none of which I can find. Thanks/Lee
   / Transmission/Hydraulic Fluid #4
Hello,
I can tell you what I would do?... I would go to the nearest Farm/Home style store. Not Wal-Mart but a real farm supply store and begin to look for equivalents. For example, I own Kubota 50hp and located an equivalent at the store. Also there are manuals that cross=reference for your model. HYDRAULIC FLUIDS ARE NOT ALL THE SAME! You will understand when you go check it out. FYI expect to spend over an hour looking around!
Don't skimp either, you will regret it in the long run.
   / Transmission/Hydraulic Fluid #5
I'd give you an 96.5% chance that Korean Shell Donaz is the same as the Shell Donat fluid recommended in the manual for my Kioti ck30hst. Can't go too wrong with a high quality major fluid.
I found mine by going to the local Shell major distributor.
On the other hand, I love that Yokong Torque Fluid 56 over rocks after a hard day at work.
Mike
   / Transmission/Hydraulic Fluid #6
If it wants torque fluid 56.. which I think is a fina product.. ANY generic UTF you get at TSC or walmart.. should do ya.
Our company used to buy TF56 from fina by the barrel when we used a distribuitor carrying fina products..
soundguy
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A52377)
2012 International...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
Peterbilt 377 Semi-Truck (A55218)
Peterbilt 377...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
