Transmission hydraulic fluid filter
   / Transmission hydraulic fluid filter #1
herd
Bamberg, SC
JD 5203
First of all, let me say that I know very little about tractors, since I was raised around mules, not tractors. Anyways, I have a JD 5203 for 2 years now and love it but still learning. I have been slowly clearing a 2 acre strip by my house which was covered with mostly scrub oaks and large pine stumps left over fm a clear-cut in 2007. I managed to run up on one of these pine stumps and got stuck, really stuck. I was lucky tho, I was stuck on the metal box under the "live pto" and no damage to anything.
My son tried to pull me out with a 4x4 blazer and we managed to move the tractor but not get it out. The tractor moved a bit and when it did, it moved over on the stump and severely dented the transmission filter against the stump. Althought dented, there was no leakage.
I managed to get off the stump with the aid of a neighbor and his backhoe. I immed checked fluid levels and all was fine. I ran the tractor for several hours and fluid level stayed intact.
So, my question is twofold: With the fiilter badly dented, but still sealed, did I hurt anything by continuing to operate the tractor. Secondly, can I get by with just swapping out the filter or do I need to change the transmission hydraulic fluid as well. In looking in the owner's manual , it says that this tractor's capacity is 10 gallons, that's a lot of fluid and I think it's pretty expensive. I am fixed income so dollars matter a lot, but I prefer to do things for the long term when I can.
Also, how do you remove a filter this size? Do I need to buy a special wrench? Any and all suggestions are welcomed and thanks in advance.
   / Transmission hydraulic fluid filter #2
I would just change out the filter first and monitor the system for anything abnormal.
   / Transmission hydraulic fluid filter #3
You could have damaged the filter internally, allowing dirty oil to go through. I would change the filter ASAP and don't worry about the oil.
ISZ
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
SAKAI SV544 SMOOTH DRUM ROLLER (A52706)
SAKAI SV544 SMOOTH...
9202 (A50322)
9202 (A50322)
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A53473)
NEW 2025 Load...
2017 TRAILSTART 40FT DUMP TRAILER (A54607)
2017 TRAILSTART...
