transmission hot
   / transmission hot #1
lippy
west central florida
yanmar 1510
i have a 1510 and after a few hours of mowing on level ground the transmission and rear end becomes very,very hot to the touch ,is this normal or do i have something about to go wrong. thanks in advance and have a great day ps all fluids are full with fresh oil and filled to full mark
   / transmission hot #2
</font><font color="blue" class="small">( very hot to the touch ,is this normal )</font>
Probably, hard to say without knowing the actual temperature. One thing that's been discussed before is that it's normal for the oil to reach temperatures of 100 F over the ambient temperature. Now that will definitely be hotter than you could hold your hand on unless it's pretty cold winter time. /forums/images/graemlins/laugh.gif I once discussed this with a dealer who said they never measure the temperature; if it doesn't discolor the paint, it's OK. /forums/images/graemlins/shocked.gif I don't think I'd go quite that far, but hot to the touch is normal. /forums/images/graemlins/wink.gif
   / transmission hot #3
Subject: Re: transmission hot
Lippy, why dont you try a different brand of oil
like case brand (hytran), or a high quality one.
I had that problem & it cured it, be sure to clean your filter in between oil changes too.
Ern.<><
   / transmission hot #4
<font color="blue">( after a few hours of mowing... the transmission and rear end becomes very,very hot to the touch ,is this normal ) </font>
Well... /forums/images/graemlins/smile.gif I was cutting last week... and after about 4 hours... I bet I could have almost fryed some eggs on the transmission cast iron housing... /forums/images/graemlins/shocked.gif
So to answer your question... Yeah it's probably normal... unless it's turning "molten red" or something with steam coming out... /forums/images/graemlins/blush.gif /forums/images/graemlins/smile.gif
   / transmission hot #5
I think all gear boxes and trans get hot when using hydralics, engine heat, clutch heat and the general stresses in engine and drive train the heat saturates the tractor I've used my tractor for 2-3hrs i'd quess trans temps run ~160 or so? I'll break out the IR temp gun next time i mow in about 2 weeks and see what it reads..
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
2023 Bobcat E32i Excavator (A51573)
2023 Bobcat E32i...
JOHN DEERE 8245R LOT NUMBER 270 (A53084)
JOHN DEERE 8245R...
