Transmission help on yanmar 180 d
   / Transmission help on yanmar 180 d #1
cliff frey
wenatchee, wa
yanmar 180 d
Can any of u gentleman, or ladies provide guidance on this transmission.
   / Transmission help on yanmar 180 d #2
Welcome to the forum. :welcome:
what kind of guidance? Where the gears are? overhaul?
   / Transmission help on yanmar 180 d #3
It's a conventional geared transmission, not hydrostatic or Yanmar's own PowerShift.
Was that the question?
I want to do some discovery, find the problem. I going to purchase repair manual ( if they have one). It appears the main transmission is below tractor seat. The access plate has a I think a hydraulic pump? On top of it. Can I remove plate and pump in one assembly?
   / Transmission help on yanmar 180 d #5
Haven't told us what the problem is? There is a repair manual for the 180. The access plate you are talking about is not a pump. It is the 3 point lift assembly including the control valve. It can be removed as one assembly. The hydraulic pump is up on the right front of the engine. The high pressure line from that pump will make its way back to the 3 point control valve.
Here is an original Yanmar YM18 & YM18D Diesel Tractor Service Manual in Binder Complete . S26 | eBay or you can go here for one. Yanmar Service Manual -- READ DESCRIPTION --: Yanmar Tractor Parts
I have one forward gear in both hi/low. 2nd I think. No reverse . I was pushing snow and working it hard , I was also low on fluid. That's all I know.
   / Transmission help on yanmar 180 d #7
So the other gears don't work? Can you shift into the other gears? And if so they don't move the tractor? Need a little more information still.
   / Transmission help on yanmar 180 d #8
Is the shift lever stuck, or it feels like it's not connected to anything?
Shift lever not stuck. I took top of shift lever housing and tried to move levers manually but could not. Lever did feel proper and functioning though when shift housing on. U guys are great .
1999 24DTA pintle hitch trailer (A52748)
1999 24DTA pintle...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
Year: 2013 Make: Kia Model: Soul Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 144,857 Plate: (A51694)
Year: 2013 Make...
2011 KENWORTH T800 (A52472)
2011 KENWORTH T800...
2018 John Deere 460E Articulated Dump Truck (A52748)
2018 John Deere...
2008 INTERNATIONAL MA025 REEFER BOX TRUCK (A52577)
2008 INTERNATIONAL...
