Transmission grinding
   / Transmission grinding #1
choopes
Troy, Al.
Snapper rer 30128BE
I have a snapper 30128BE r.e.r. My nephew put together from mixed parts. The 12 hp B&S motor came off a sears LM. It's done well for me for 3 seasons. It started to have trouble climbing hills. Now it makes a grinding noise especially when I mash the clutch. There is no more nuetral anymore. When this started I replaced the drive wheel, the one with the rubber ring, and the gasket material clutch, but that didn't help. So I'm looking at it. The drive wheel has moved dead center to the horizonal plate that is mounted on the engine crank.What is supposed to hold that stationary? There is a yoke with a slotted opening assumed to be for ajustment. But mine has no nut, or locking mechanism. Is it supposed too? The grinding is worse when I try to put it in reverse. What is the problem? and how can I fix it?
THANKS
   / Transmission grinding #2
I'm not familiar with the machine at all but have you looked at tranny and engine mounts to make sure the mounting hardware hasn't torn or dented the thin metal? You might try Google for some previous history on that kind of problem or even Youtube...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
1264 (A50490)
1264 (A50490)
2012 Mack GU713 T/A Gardner Denver Kill Truck (A52377)
2012 Mack GU713...
2019 RAM 2500 Crew Cab Pickup Truck (A53422)
2019 RAM 2500 Crew...
