transmission fluid
   / transmission fluid #1
dhelsel12
shibaura d26
i have a 1992 shibaura d26 diesel, it is geared and i'm trying to figure out if it has a seperate reservior for tranny fluid and hydraulic fluid. it has one reservior behind the seat that the hydro lines run over and a dip stick in the cab area that appears to be where you check the levels, both fluids are milky clear, but i'm not sure. this is my first tractor and i'm still figuring all this out. i'm also trying to figure out the oil filter size, any store best at matching.
2008 Komatsu WB146-5 (A47477)
2008 Komatsu...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55218)
Kubota BX2680...
2011 Doonan 482FBCHTTDBZ 53ft 40 Ton T/A Flatbed Equipment Trailer (A52377)
2011 Doonan...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
Unused 2025 LandHonor LDH-KN16 Mini Excavator (A52377)
Unused 2025...
2004 Ford F-250 4x4 Service Truck with Liftgate (A53422)
2004 Ford F-250...
