Transmission Fluid, How much is to Much???
   / Transmission Fluid, How much is to Much??? #1
Jer
So. California
Two tractors..both Mitsubishi. MT160D 4WD with a Brush Cutter. The other is a MT1601 4WD with a loader
I just finished doing full maintenance on my MT160D. After changing my Transmission/Hydraulic fluid and installing a new filter, I put the recommended 12-2/3 quarts of fluid in and expected the fluid to overflow through the Oil Level Plug hole, per the Manuel. Nothing came out so I added another quart. Still no overflow. I added another 2 quarts, still nothing came out the overflow. That’s a total of 16 quarts of fluid in the system. I ran a wire in through the oil level hole thinking it may be clogged but there were no obstructions. Should I drain out some of the fluid or just leave the 3 quarts over the recommended quantity??? I’m worried that the extra oil may damage the system. Does anyone have any savvy on this topic???? My 3 point and transmission are working ok but I’m concerned about the extra fluid, and why it didn’t come out the overflow hole.
   / Transmission Fluid, How much is to Much??? #2
Well I'm no expert but I had to change my oil before I got the manual, so, I dumped the whole five gallon can of oil in my tractor. That just about filled it to the top and I ran it for a year like that with no problems at all. A tiny bit came out the vent hole when I was bouncing around alot but that was it.
   / Transmission Fluid, How much is to Much??? #3
If the level is not to the check plug , it is not over filled. A transmission or gear box should be around half full. I'd be more concerned about how full it is than how many quarts it used. The book may have a mis-print. If they are overfilled it can lead to blown seals..
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
UNUSED INDUSTRIAS AMERICA F10 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
JOHN DEERE Q820M LOT IDENTIFIER 229 (A53084)
JOHN DEERE Q820M...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53472)
2022 MAXXD BD14...
