Transmission differential hydraulic fluid type
/ Transmission differential hydraulic fluid type #1
cleat
Brockville, Ontario, Canada
Dongfeng 254G2
My Dongfeng 254 uses a common reservoir for the transmission, differential and hydraulics. I keep the tractor in a slightly warmed garage (kept just slightly above freezing). Hydraulics function noticably slower when first started and moved outside than in summer. However as I use the tractor outside in cold conditions to clear snow, the hydraulics get even slower as the fluid cools even more. Everything works fine, just slow. I bought universal TDH fluid from walmart last year and that is likely my problem.
What I would like to know is, has anyone used a high quality TDH fluid and what were your experiences
I can get two different shell fluids at my local TSC store. Spirax S4 TXM and Spirax S4 CX. Would either of these help ?
Would adding some ATF help ?
Any suggestions would be appreciated.
Cleat
/ Transmission differential hydraulic fluid type #2
AWE32 Hydraulic oil should be fine for cold weather, I live in Quebec and we got -40F not long ago, it was alright on my Jinma.
what is the AWE of the oil you are using?
My Dongfeng uses a universal transmission, hydraulic differential fluid in a common 25l reservoir and the walmart stuff I put in has no rating. It only says it is compatible with a wide range of manufacturers. If I had a separate hydraulic oil reservoir linke your Jinma it would make my decision on oil easier.
Cleat
/ Transmission differential hydraulic fluid type #4
/ Transmission differential hydraulic fluid type #5
Hi cleat,
I have the df 354 with common sump. I have used Walmart utf without any winter issues. I only have slow hydraulics at the very start. As soon as the engine comes up to a steady idle all is smooth.
Dave
Mine is smooth, just noticably slower.
Likely nothing to worry about, I was just thinking out loud.
Cleat
/ Transmission differential hydraulic fluid type #7
I dont know why i added a "E" I meant AW for anti wear
Pallet of Fork and Frame Mini Skid Steer Attachment (A61567)
Pallet of Fork and...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
New/Unused IRMC Massage Chair (A61166)
New/Unused IRMC...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
2018 JCB 3TS-8T SKID STEER (A62129)
2018 JCB 3TS-8T...
