Transmission belt
   / Transmission belt #1
zrrick
Lapeer, MI
Cub Cadet
How do I replace the transmission drive belt on my GT1554 tractor. It looks like I have to remove the PTO clutch, but how do I remove it. How do I hold the crankshaft in order to remove the 5/8 bolt on the bottom of the clutch???
   / Transmission belt #2
There are some tabs on the frame around crankshaft hole, cut these off with a grinder/ cutoff wheel,they are ment to hold the belt on, but not needed. Otherwise, you have to remove clutch and engine mounting bolts. If you remove the clutch, an impact will work. Navigate to the lawn and garden section for more info.
Dave
2017 DODGE RAM 3500 SERVICE TRUCK (A52472)
2017 DODGE RAM...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
