Transmision vent tube?
   / Transmision vent tube? #1
kuby
Alberta, Canada
L 245DT
Is there a vent tube on a L245DT? I have blown out two axle seals and notice a little pressure when I remove the cap.
Anyone??? /forums/images/graemlins/confused.gif
   / Transmision vent tube? #3
I bought a l225 a month or so ago and have the same question. I have not had any seals blow out yet but I have noticed pressure on the filler cap when I remove it after the tractor has warmed up.
Hey guys any answer on this one ??
   / Transmision vent tube? #4
I don't have that model tractor, but I know that all gearboxes should vented as from as I'm concerned. My front axle on my BX2200 released pressure when I released the cap. I tapped in a vent there. My main transmission already has a vent. My Kubota dealer said that the front axles were not vented because Kubotas were made to run in deeper water (rice paddies). I'll keep mine on the higher ground, but hope that I won't blow any seals. /forums/images/graemlins/cool.gif
   / Transmision vent tube? #5
Rice paddies??
That's a new one!
I may try to put one in then. The hydraulics pump fluid from the tranny as well so would a vent be required for them as well or would fluid squired out of it??? I know my tires are refered to as rice tires because the lugs were longer than most I have seen.
   / Transmision vent tube? #8
kuby,
I have thought about this and wonder.....if the fluid gets warm and expands enough to create pressure ( a concern we have both expressed at this point ) does that mean that the crankcase ? would draw in fresh air as it cooled...would the fluid have to be changes more often ??
I live in a high humidity aera where I see everything destroyed by it.
just a thought ....
   / Transmision vent tube? #9
Yes tranny vents are a mixed blessing. They do draw in moist air when they cool and it condenses causing moisture in your tranny fluid. But if you don't have a vent they can be difficult to keep seals in. On the Kubota front axle no vent thing, maybe the front end rarely gets hot enough to need to breathe ?
   / Transmision vent tube? #10
On a L4850 I use frequently, there is no vent on the axle. After many hours of use in hot conditions, the pressure does build up. At most it would seem to be less then 1 PSI. I doubt any seals are going anywhere with that small amount of pressure. It's not had an issue now in 12 years. I think were going to be OK.
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A54313)
2012 INTERNATIONAL...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2011 4300M7 International (Pavo, GA) (A50123)
2011 4300M7...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
