trans. shifting problem
   / trans. shifting problem #1
donawilcox
Taylor TX/Austin
still looking
not called the dealer yet but a few weeks ago notice I was having problem getting my 3540 to changes gears. Actually the first time I notice it I pulled out of 3rd and thought I went to 1st and then it was stuck in that position drove a little more and tried again and it came out. Currently I am not having any problems shifting from 3rd to 4th but can not get it over to 1st or 2nd gear. I tried adjusting the clutch but no change but may not of gone far enough. the fluid is full. I did find a grease cert on it today which did not know was there. have to crall under to find it.
Let me know if anyone has had this issue.
Don
   / trans. shifting problem #2
Mahindra is not the sort to put money on. not bad but neither good either.
   / trans. shifting problem #3
Don, How many hours are on the tractor??? How's the fluid level in the transmission???
   / trans. shifting problem #4
Don
Assuming the tractor's still under warranty, I wouldn't have adjusted anything. Especially not the clutch...
   / trans. shifting problem #5
Do you have any ideal what your talking about?
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
Bobcat Skidloader Breaker (A50774)
Bobcat Skidloader...
Kubota RTV1100CR9 (A47384)
Kubota RTV1100CR9...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Spool 16mm Wire Rope (A47384)
Spool 16mm Wire...
