Trans oil
   / Trans oil #1
RICHIE K
I have a 485x with the loader attacment do I have to use the jd trans oil or another type is ok ? If so what kind ?
Richie K
A FULL SERVICE COMPANY
   / Trans oil #2
Welcome to TBN!:D
I always use the JD branded oils, they really do not cost more when compared to other name brand quality products.
   / Trans oil #3
Nope, no reason to have to use the JD oil. There are numerous manufacturers of UTF's that meet and exceed JD spec oils. Some better than others just like everything else.
   / Trans oil #4
I found your X485 manual on-line at JD website.
"NOTE: Machine is filled with John Deere Low Viscosity HY-GARD® (J20D) transmission oil at the factory. DO NOT mix oils.
These machines are equipped with a internal wet disc brake transmission. Use only Low Viscosity HY-GARD (J20D) transmission oil. DO NOT use type "F" automatic transmission fluid.
IMPORTANT: Avoid damage! Use John Deere Low Viscosity HY-GARD (J20D) transmission oil to reduce transmission noise and to increase response time for the hydraulics and power steering.
John Deere Low Viscosity HY-GARD (J20D) transmission oil is specially formulated to provide maximum protection against mechanical wear, corrosion, and foaming."
It is the same with Kubota. They have a SUPER UDT or a regular UDT hydro fluid. One is Low Visc. the other is 'regular'.
2016 Caterpillar 349FL Hydraulic Excavator (A55787)
2016 Caterpillar...
1996 JCB 506B Telehandler (A55301)
1996 JCB 506B...
Enmark Z Spray (A53316)
Enmark Z Spray...
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2004 Volvo XC90 VAN (A55853)
2004 Volvo XC90...
New/Unused 72in Quick Attach Skid Steer Tiller (A54865)
New/Unused 72in...
