trans oil for a FORD 4140 / 4040 ?
   / trans oil for a FORD 4140 / 4040 ? #1
Big Hammer
Bronze Member
I have misplaced my service manual for this tractor...
It is a 60's model, been sitting inside for over 20 years. Got it running, but low on tranny oil.
It is a manual transmission, and it has a reservoir up front for the loader / backhoe, so I don't think it shares the same fluid as the hydrolics (?)
I am no mechanic... don't know if it has a 'wet clutch' or not.
OOPS hit enter too soon
Anyway, can somebody tell me what oil to add into the trans? 80-90wt? Universal tractor fluid?
PLZ help!
thanks
Mark
   / trans oil for a FORD 4140 / 4040 ? #3
I believe tractor fluid meeting the older Ford/NH 134 spec would be the correct fluid.Not hard to find.If transmission only,I doubt using gear lube would be harmful.Kubota UDT or Penzoil Hydra-Trans exceeds that spec.Good Luck.
   / trans oil for a FORD 4140 / 4040 ? #4
i'm not familiar with those units.. but if it is a closed sump tranny that doesn't share oil with any other sump.. gear oil should be fine.. that said.. utf oil meeting the M2C134D spec would work as well.. and would probably be what a dealer would reccomend to you..
soundguy
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2004 INTERNATIONAL 4300 BOX TRUCK (A54607)
2004 INTERNATIONAL...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2014 BMW 328i Sedan (A53424)
2014 BMW 328i...
CATERPILLAR 312E EXCAVATOR (A52706)
CATERPILLAR 312E...
