Trans/Hydraulic drain plug size TN65
   / Trans/Hydraulic drain plug size TN65 #1
n5oxp
I am going to change the trans/hydraulic oil in my TN65. I will have to purchase some metric sockets and I need to know what size mm sockets are required for the drain plugs. Thanks
   / Trans/Hydraulic drain plug size TN65 #2
27mm 6 or 12 point socket and 12mm allen wrench and 22mm 6 or 12 point socket will drain and fill just about everything.
   / Trans/Hydraulic drain plug size TN65 #3
Get ready for a real treat. I watched my neighbor get the drain plug out on his TN the first time and he actually bent a cheap wrench before it came loose.
New Holland really puts the torque to them initially.
   / Trans/Hydraulic drain plug size TN65 #5
The factory installed filters are tightened well beyond all reason, too.
Also, get a good strap wrench, or pliar type filter wrench for those filters - you will need it - especially for the oil filter.
A FEL makes changing the oil filter the first time even more challenging. /forums/images/graemlins/blush.gif
You may have received an allen wrench with your tractor - I did
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
WOODS RC60.20 LOT NUMBER 88 (A53084)
WOODS RC60.20 LOT...
2023 JOHN DEERE 8R340 LOT NUMBER 221 (A53084)
2023 JOHN DEERE...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53472)
2020 New Holland...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
