Trans hyd fluid
   / Trans hyd fluid #1
eddieirvine
Indiana
Kubota L 3940
What is the best hyd trans fluid for Kubota besides the high priced kubota utd fluid? I have been reading up on several that are as good or better, even some with synthetic oil added. what are your thoughts on this?
   / Trans hyd fluid #2
This has been a hotly contested topic here in the past and you're sure to get a lot of opinions.
Although there are many oils out there with similar specs, my preference has been to stick with Kubota SUDT2 trans oil. Yes, it's expensive but how often do you change it. How much do you really save? I consider the extra cost to be a bit of insurance against any possible warranty issues. Although rare, Kubota has denied warranty claims on damage caused by oil that does not meet their specs. Product labels aren't always accurate.
For example, a guy here in town had to pay for an expensive repair because he did the first oil change on his L3430HST using a product he bought at TSC. He showed the product label with specs to the Kubota rep who claimed when tested, the oil did not meet those specs. An isolated case? An error on the part of the oil company? Probably, but it was verified by the service manager who I know quite well.
I'm sure someone will post that this is all bull, rumor and hearsay. You can believe what you like but my opinion is, why take a chance.
   / Trans hyd fluid
thanks for your advise and I see what you are saying and truly understand it thank you dbhsfz6
   / Trans hyd fluid #4
Stick with SUDT2 if you have a HST or GST. It just performs better. Generic hydraulic fluid should be fine if it's a basic gear machine.
   / Trans hyd fluid #5
I stick with Fluids and Filters from Kubota. I buy when i'm in the USA instead of from Canadian Dealers.
Miller Wildcat 350-D Welder (A51691)
Miller Wildcat...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
6ft Pull Type Hydraulic Dirt Pan (A51573)
6ft Pull Type...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
