Tranny Problems.....L35
   / Tranny Problems.....L35 #1
Kubota-monkey
Massachusetts USA
L35 with bt900 backoe and box scraper + grader blade
On my L35 the transmission seems to take a lot longer to engage than it should. It also does not shift smoothly and rather seems like it is jammed into gear. I checked the hydraullic oil and everything seems fine. Anybody have any ideas on this>? /forums/images/graemlins/confused.gif
   / Tranny Problems.....L35 #2
How many hours are on the L35? How long has it been since the hydraulic oil filter was changed? Also, could it be the cold weather? Are you using a synthetic hydraulic fluid? These L35's will not perform well in cold weather with a non-synthetic hydraulic oil!
Jon
   / Tranny Problems.....L35 #3
Hey Ben, we need a little more info. Is your machine between ser.#50001-50868/60001-60878? How many hours? Are you using super UDT? Does it improve after it's up to normal operating temp? How does the power steering feel, high rpm and idle (GST and steering come off of the same pump)? Does it shuttle between forward and reverse OK? Are the shifts aggressive and slow? Can you hear a slight grinding when the gears shift? Check 1-8 any difference between 1-4 and 5-8? Do you have to play with the shift lever at all to get it to shift? Answers to these questions will help narrow it down some.
Its really weird...... the shifting seems to work fine in the first few minutes then when it warms up thats when the problems start. The gears make somewhat of a grinding noise but only for a moment. The problem appears when shifting from forward to backwards and all gears 1-8. POwer steering works fine along wit hall implements and the hydraullic filter might have been changed about a year and a half ago. Shifts are definetly agressive and slow....thats the best way to describe them.
   / Tranny Problems.....L35 #5
Ben, I will attempt not to write a book about GST, so I'll give you the short story; Inside the trans you have a hydraulically engaged spring released clutch pack. On the left side of the trans just below the floor board you have the GST valve assy. All transmission shifts are done with hyd shift pistons located in this valve and connected to a mechanical shifter. With the exception of fwd/rev shuttle. Fwd and reverse is shifted manually, however, there is a "release pin" in the valve that the shuttle shaft depresses while in transition from fwd to rev and rev to fwd that dumps clutch pack pressure and disengages the hyd clutch untill the fwd or rev gears are engaged. Now, you have four gear sets in the trans, fwd of the clutch pack, aft of the pack you have the hi-lo gear set and the fwd-rev gear set all of which are synchronized. In gears 1-4 the hi-lo set is in low range, in gears 5-8 the hi-lo set is in high range, hence 8 speeds in fwd and rev. The gear shifter itself is cable operated and runs down to the GST valve. The cables have a tension adjustment. The cables move a rotary valve that ports fluid through a manifold that determines what shift pistons to port fluid to, to shift the trans to what gear you select, at the same time, during the shift, clutch pressure is dumped to provide a smooth clean shift. After the shift is made clutch pressure rises and engages the clutch pack. The shift is made and you are on your way. So, when making a shift from 0 to 1, You move the shifter, the cable moves the rotary valve which ports fluid to the 1-2/5-6 shift piston and dumps pack pressure, pressure builds in the shift piston, moves the shifter and engages 1st gear, clutch pressure buids back up through an accumulator in the valve assy, which allows pressure to build gradually and engage the clutch pack. When going from 2-3 the 1-2/5-6 piston shifts to neutral and the 3-4/7-8 shift piston shifts the gear set to 3rd gear. Same process to fourth. Now when going from 4-5th gear, the 1-2/5-6 piston shifts back to the 1/5 position, the 3-4/7-8 piston shifts to neuatral. At the same time, the hi-lo set shifts to hi range, thus the longer pause going from 4-5th gear. O.K., still with me? In the lower gears 1-4, pack pressure needs to be brought up more gradually to prevent hard aggressive shifting, but in the higher gears, pack pressure needs to be brought up quicker to prevent too much lag between shifts, so a low pass and a high pass valve in the GST valve assy compensates for this difference.
Why did I explain all this? Because what you are describing sounds like the clutch pack may not be disengaging completely between shifts. A restriction (foreign object) in the GST valve assy, warped clutch discs or an obstruction in the pack may be causing this. ALL the synchronizers in the trans being bad sounds unlikely, but not impossible.
   / Tranny Problems.....L35 #6
WOW,,, Bravo Kubmech..... Tons of info for us regular folks... /forums/images/graemlins/tongue.gif /forums/images/graemlins/tongue.gif/forums/images/graemlins/grin.gif
Let us know how you make out with you problem because we're all hoping the best.
Darin
   / Tranny Problems.....L35 #7
Ben, I was thinking, the heavier the machine is loaded, the more noticeable the shifts and noise associated with the shifts. That is normal. Usually the problem you describe is opposite, works better as the machine warms up, that was one of the major reasons for using super UDT in the GST tractors in cold climates. I can only go by your description of the problem, too bad you can't put a sound wave in your post.......................
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A51692)
2006 Ford F-550...
2009 Freightliner M2 106 Ambulance (A51692)
2009 Freightliner...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
