Tranny/hydraulic fluid for Mahindra
   / Tranny/hydraulic fluid for Mahindra #1
magyarbacsi
Two issues.I recently changed the fluid in the tranny in my 5525 with 0nly 50 hrs (in 3 yrs) and my dealer said to use Napa UTF. I used Mahindra filters and did clean the screen at the bottom of the tranny.( not the easiest job as I have a custom full frame for the bh and brakepeddals have to be moved) Everything works as it did before except for the Bradco 509 bh bucket. Oddly, it works to dig and rip, but the jaw is slow to open. The swing, boom, dipper all work fine, just the bucket opening very slow. I noticed that the factory fluid that I drained had a lower viscosity than the Napa that was suggested. When I use the spool valve to open the bucket it makes noise similar to when you bottom out on the hydraulics, but the bucket is nowhere near the end of its travel. Unfortunately, my warranty is expired. Bought the rig in 07 and have not used it much as you can see, so no longer covered.
I will do one more oil change and looking for the Mobil 424, as was suggeted by another dealer, not near me. I live in Washington and cant find any local dealer or trucking company selling that product. It is availabe online, but shipping is the price of another bucket. Any WA residents have knowledge where I can purchase locally or a sismilar product? Acculube has it for around $70/5 gal, + around $60 to ship.
   / Tranny/hydraulic fluid for Mahindra #2
Remove the cyl from the bucket and see if it swings freely. Then run the cyl out and in and check for correct operation.
How is your grapple jaw connected to any valve. Is the grapple jaw on a separate valve or using one of the spools on the BH.
Have you rechecked all the QD's for full flow. Some of the QD will look secure, but be jammed up orpassing little fluid or none.
Have you installed a gage in the hyd circuit to check pressures.
Just opening and closing a bucket or grapple should not make the relief activate. To get high pressure, there must be some resistance against the hyd flow.
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2008 Ford F-550 11ft Flatbed Truck (A52377)
2008 Ford F-550...
2025 GIYI VR66 66in Vibratory Roller Skid Steer Attachment (A53421)
2025 GIYI VR66...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2007 JLG 600S TELESCOPIC MANLIFT (A52705)
2007 JLG 600S...
