Tram Issue on 1845
   / Tram Issue on 1845 #1
marrt
Platinum Member
Northern VA
Power Trac 1845 and 425
I think you have an issue with your tram control. I assume you have the hydraulic foot pedal and not the cable. I think there is a way to detune the reaction of the Tram control. I have to adjust mine one of these days as i creep forward when stopped. Terry says it is an easy adjustment.
To keep from hijacking the other thread, I started a new one.
I have an older machine with the cable. I can watch the cable move on the pump. So, I'll push the cable forward slightly (or backward, doesn't matter) then stop, in about a second, the machine will lunge. It's almost like pressure has to build. Of course, if I floor the tram, it moves almost instantly.
And here's the kicker...this doesn't happen every time I change direction or stop and start. Further, if I engage the tram and don't get an immediate response, I can usually engage in the other direction, then back to the original direction and it will not lunch. For example, if I'm trying to go forward and it doesn't immediately move, I'll reverse the tram direction (still not moving) then go back to forward and it will usually move forward smoothly.
The sounds exactly like a shuttle ball type issue. However, I'm not sure my machine has the shuttle ball. I asked Terry about it a few weeks ago and he didn't seem to think it was the shuttle ball (although he didn't confirm or deny my machine has the shuttle ball...not all had them apparently).
Ok, I thought I'd post a couple videos. Never done it before, so here goes:
In this video, I reach down with my hand and pull up on the forward tram side so you can see everything without my foot in the way. Notice the camera (and my head) slam into the steering wheel.
https://www.youtube.com/watch?v=VzdFkVHL6EU
Another shot:
https://www.youtube.com/watch?v=3mVjgC4k-CM
Here's a shot using my foot to tram properly. Pretty much the definition of a tipping point.
https://www.youtube.com/watch?v=jio9GdxEn5g
Tom
Yep. You can see, in a couple video, that the machine will tram smoothly back and forth right after it occurs. But, if you come to a full stop and wait a couple seconds, the surge is there again.
   / Tram Issue on 1845 #5
Since the wheel motor circuit is semi-closed, is there any chance it is because of air in the lines?
Ken
I suppose anything is possible. But you'd think there would be additional symptoms...strange noises or pump cavitation or periods of hesitation while underway. Something.
   / Tram Issue on 1845 #7
What made me think of it was that you said it only happens when you stop for a bit which would possibly allow fine bubbles to gather. But definitely a long shot and I would think the pump would have issues by now if it was.
Ken
Terry seemed to think the problem is in the tram cable linkages. He said I could put the Tractor on blocks, disconnect the tram cable then tram the pump by hand to be sure. I'm going to try this next since it should be fairly easy to do.
So close. I put the tractor on blocks and disconnected the tram cable. I found Power Trac had attached the 1/4 inch swivel for the cable through a 3/8 inch hole on the pump. And, the swivel was not very tight so I assumed it would slip from time to time. Further, when I would tram the pump by hand, everything was smooth (with the wheels in the air though). I was SO sure I'd found the problem. I fixed the issue with the swivel and reassembled everything and...it didn't make any difference at all. Rats.
However, I did notice something. The pressure on the brake tender will vary quite a bit. When the pressure is 1500 or below, I'll get the "surge." When the pressure is 1700, no surge. You can see this clearly in the third video above. After the initial surge, I can stop and go smoothly if the pressure is 1700 or so. Not sure what is causing this pressure variation but I think this is the root cause of my problem.
   / Tram Issue on 1845 #10
Glad to hear you are narrowing down the problem. Problems like these can be frustrating. Hopefully you solve it soon.
Ken
2018 PETERBILT 579 DAY CAB (A50505)
2018 PETERBILT 579...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A48836)
2013 International...
LEE G550 MOTORGRADER (A50458)
LEE G550...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
John Deere no-till Coulters (A47164)
John Deere no-till...
Caterpillar 56in Excavator Bucket (A49346)
Caterpillar 56in...
