Trailers
   / Trailers #1
Jesse masterson
Platinum Member
Thebes il
07 kioti dk 45s
I recently purchased a 85 k 5 blazer with a 6.2 Detroit diesel runs great but when I out my dk 45 on trailer it won't pull up any kind of steep hill the tranny isn't slipping the motor Rpms slow down to a near stop then I put it in low lock 4 wd to get up a 45 degree incline do you guys think the motor is weak orwould a change of gears be on order I believe it has highway gear 307s I think I only use it rarely not a daily vehicle
   / Trailers #2
What transmission? It it or you downshifting?
You might get mere answers in the trailer forum:
http://www.tractorbynet.com/forums/trailers-transportation/
Probably not 45 degree hills you are towing up. :)
Bruce
   / Trailers
Ha maybe 35 to 38 pretty steep it has a GM 400 tranny
   / Trailers
Also I should mention I am downshifting and the motor sounds good no blue smoke
   / Trailers #5
That happened to me in a 1998 Chevy 3/4 ton pickup and it was the catalyctic converter. That was a gas vehicle though. Don't know if this helps???
   / Trailers #6
Can you use the tractor to pull the truck and trailer up the hill?!:D
   / Trailers
Thanks woody for the idea I'm not sure if diesel has catalytic converter or not I'll check at least that's a lead to follow
   / Trailers
And coyote that is a option lol but not the one I'm looking for
   / Trailers #9
If I remember right , the 6.2 had about 160 hp so I would think pulling a grade like that with a loaded trailer, 4wd low would be the only way to get it up.
just the reality of the situation.
Of course you could overhaul it put a turbo, injectors, beef up the bottom end , trans, third members. easy to get carried away and have a 30 K old blazer !!:D
If it to just be used around the property , then ya spend about 3k grand for some 5.38 gears and lockers !!
   / Trailers
Bladehauler I think your right do you think changing gears on front and back would solve problem
2003 International 4300 Dump Truck, VIN # 1HTMMAAL83H562953 (A51572)
2003 International...
2016 LOAD MAX 24 GOOSENECK (A52472)
2016 LOAD MAX 24...
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
2019 KOMATSU  D65 PXI 18 (A52472)
2019 KOMATSU D65...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
