trailering my tractor
   / trailering my tractor #1
Rustywreck
Solon Springs, Wisconsin
New Holland T 1520
It is time for my first post on TBN, other than my introductory post, and I want to thank everyone in advance for any advice.
For the first two weeks since I discovered TBN I have been reading old and current posts, and I am amazed with how much I didn't know about tractors, attachments, and their use.
I have searched the forum regarding my question and the amount of information pertaining to my question overwhelming to say the least.
My question: I have a New Holland TC1520 tractor with various attachments, including a snow blower. I would like to trailer it to a few locations (my job being primary) to do some snow removal. I will have a steep, long hill to pull up and down. What do I need for a truck and trailer to haul this thing?
I have a 1993 Chevrolet k1500 with a 4.3 V-6, 5 speed, which I know will not do the job. I have had this sorry old truck for a long time and 270,000 miles, and will not part with it so I would be looking to buy an additional used truck. Whatever I buy to pull the tractor will not have to be a daily commute vehicle - I have a little car for that.
I had my mind set on a 1-ton dump as I could make use of the dump truck, but I'm reconsidering it after reading another topic regarding them.
Sorry for making this so long, but I wanted to make sure I provided enough information. Thanks again for the advice.
   / trailering my tractor #2
A good 4x4 V8 1/2 ton will do the job. Get something with a tow package and a 7,500# or more tow rating. Your tractor only weighs 2,200# and figure 500# for a snow blower. You did not say if it has loaded tires or a FEL but on a small tractor like the 1520 you still would only be at 4,000# max then figure 2,000# for a 7K trailer.
I am really happy with my current 1/2 ton, a Nissan Titan, and was also very happy with the 6 F-150 4x4's I had between 1997 and 2007. Never had a single issue with any of them.
Just do your research. Get a low gear ratio. Just because its a V8 does not mean squat if its backed up by a high gear ratio.
Just for reference you current truck has a 3,500# tow rating according to my book. If it had a auto tranny it would be 5,000#
Chris
   / trailering my tractor #3
Rusty Wreck IMHO. Chris has hit dead on the money.A late model 1/2 ton v8 should be plenty for your needs. I have a 01 F-250 with a 5.4 and 3.73. My tracktor weighs pretty much the same as yours,and use a 7k trailer also. It is pretty much an over kill for my needs now. I bought the truck to pull my Ranger bass boat so I was using it mostly for Hwy. travel so opted out on 4wd. and rarely if ever go off road with it,thats what the atv. is for:p.With the ride and handling I believe it was a good choice for me. If I was in the market today for a new truck a F150 would my choice or 1/2 ton.
Carey
   / trailering my tractor #4
   / trailering my tractor #5
Trying not to mean to buy just a Ford.I know how people get by the Manufactuer on here:rolleyes: Hummm!
Carey
   / trailering my tractor #6
ditto on the 4x4 v8 1/2 ton as a minimum.. though I might look for a 3/4t or dually.. even an older one.. that and a 16' tandem trailer minimum.. if not an 18 or 20 foot with or without beaver tail.
electric brakes on whatever axles the law in your area says.
soundguy
   / trailering my tractor #7
ditto on the 4x4 v8 1/2 ton as a minimum.. though I might look for a 3/4t dually.. even an older one.. that and a 16' tandem trailer minimum.. if not an 18 or 20 foot with or without beaver tail.
soundguy
3/4t Dually?:D May I see one?:p
Sorry, couldn't resist, don't want to start any fights...
KYle
   / trailering my tractor #8
soundguy
Not to get all technical here but I have never seen a 3/4 ton dually. Only 3/4's I have seen are SRW and all the duallys I have seen are 1 tons and bigger except for the one offs like the Dually Ranger I pulled out of the ditch 3 or so years ago and there is a Dually Suburban about 2 miles from my co workers house. I remember some time ago seeing dually kits in JC Witney so I know anything is possible.
As for the brakes in WI they are required on any trailer of 3K. No mention of brakes on all axles but if buying new its a well spent extra $150. Also no mention of a brake-away but I would not own a trailer with brakes without one. The whole brake-away system is less than $50.
Chris
   / trailering my tractor #9
Guys.. remember I type on a netbook with 8" screen and a keyboard the size of 2 pieces of 'short' toast.
I missed 'or'.
glad you caught me on it. has since been edited.
now let the floggings continue
soundguy
   / trailering my tractor #10
I missed 'or'.
soundguy
We have to catch you when you make a mistake. You know its all in good fun. You are usually 99.99% on the money.
Chris
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
2025 INDUSTRIAS AMERICA 227T 7' X 22' HYD TILT TRL (A51247)
2025 INDUSTRIAS...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
(1) HD 26ft x 24ft Full Garage Kit Metal Building Frame (A51573)
(1) HD 26ft x 24ft...
New/Unused AGT Industrial SDA-140T Track Loader (A51573)
New/Unused AGT...
JOHN DEERE Z530M LOT NUMBER 170 (A53084)
JOHN DEERE Z530M...
