Trailering a Car
   / Trailering a Car #1
RobS
Super Member
Goshen, IN
None!
Maybe slightly off topic, but I know there are a lot of us on this board with trailers. Here's my situation: I have a car-hauler trailer that I have only used for my tractor. It's 18', 16' flat w/ 2' dovetail. 5' ramps. Again, I have used this many times to haul my tractor, so I am plenty familiar with the trailer.
Of course, I pull the trailer with my truck which gets miserable mileage. So, I'm buying an economy car. Picking it up next week, 200 miles away. No problem, take the trailer and make a nice day out of it.
I'm curious though, as the car has no-where near the ground clearance of the tractor. Any tricks/tips to loading to avoid bottoming the front/back and middle as I cross the dovetail? The car is a first generation Scion xB (the "Box"). It sits fairly low, but is stock. There is little rear overhang but the front has some and of course the middle going over the angle.
I have access to a tow dolly, which sits lower. I've never used one before and would prefer to have the car on my trailer.
Suggestions?
   / Trailering a Car #2
The only vehicle that I have problems with on my equipment trailer is my racecar because of the long tube headers and 3.5" exhaust over the edge on the dovetail.
Got a picture of your trailer with the ramps set up? I'm going to go out on a limb and say you'll be fine.
   / Trailering a Car #3
Rob,
I'll bet it will clear the hump just fine. You could find a spot where there is a slight hill, and back your trailer up to that to lessen the angle of the ramps, but I'll bet it won't be a problem.
On our car hauler, on level ground, the ramps end up about the same angle as the hump, maybe a tad more, but not much. Here's a couple pictures of mine.
Picture 1
Picture 2
Lot of folks use these same trailers for race cars and such and they are pretty low to the ground.
Just remember that the car has a suspension and should be secured well, as they can bounce around a lot more than a tractor.
   / Trailering a Car
Thanks for the pics Dave, your trailer looks pretty much like mine. I'll check it out this weekend.
   / Trailering a Car #5
My trailer is an older home made car trailer that sits higher than most car trailers, and I have loaded several cars on without problems. I think the car you are talking about has a short wheelbase, which will help out a bunch. It's the longer wb sports cars that give trouble. My '93 Firebird drags the hedder flange on the wood planks for about 2" when I load it.
Also, what kind of ramps do you have. I have found out that the construction type ramps (Upside down Angle Iron) do not work well for vehichles, esp. small cars. The angle iron is spaced too raf apart and the tires want to drop in. It's like driving over a bunch of little speed bumps.
   / Trailering a Car #6
Does the car have a sun roof ?
Think this question through... CAREFULLY !
   / Trailering a Car #7
Reminds me. Last year I made a pulley to go onto the back of my trailer so I could pull vehicles off the trailer. Make the winch that much handier. I designed it, welded it, sandblasted it, nice job!
Course the first car I pulled onto the dovetail couldn't clear the 2 1/2" high pulley and thus the whole plan went to ****..
:( Very disappointing!
Hmm, gues I could now mount something to make the car and inch or two higher... hmmm
   / Trailering a Car #8
Just thinking Rob...You could take some 2x6's (maybe 2 or 3 feet long), and place them under the ramp ends on the ground. That would flatten the ramp angle by raising them. If you stack the boards, stagger the ends so you can drive up them onto the metal ramp. Sort of a wooden ramp under the end of the metal ramp. Hope this makes sense.
   / Trailering a Car #9
I do not think you will have a problem. If you do need a little more clearance just crank up the front of the trailer till you get it to pass, lower it and tie it down. We always find some where on the front to tie it down so the suspension of the car your hauling can move up and down. Always tied of the rear end in the back.
Wayne
   / Trailering a Car #10
I haul about a dozen cars a year for family and friends. I did just as you did last Wednesday and bought a 1999 Saturn of the net. It was only 75 miles away but I hooked up the trailer to my F-150 and went and got it.
Here is a few things I have learned hauling about 40 or so cars, suv's, and trucks.
1: Take some 2x8's about 5' long. You may need them to put over the ramps or to lessen the approach angle.
2: Never hook the straps or chains to the frame of the car. Only hook to the suspension. I use axle straps and hook to the lower A arms on the front and to the rear suspension. This allows the car to bounce separate from the trailer. If you hook any other way the chain/strap will come off as the suspension compresses at bumps.
(Car transporters hook to the frame but pull the car down vertically to fully compress the suspension, that is ok but not practical with a trailer)
3: Cross the chains/straps in a X fashion to prevent any side movement of the car on the trailer.
Hope this helps.
Chris
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A52576)
2014 HINO 338 26FT...
More info coming soon! (A50322)
More info coming...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
MILLER SYNCROWAVE 351 TIG WELDER (A52472)
MILLER SYNCROWAVE...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
