trailer wiring
   / trailer wiring #1
farmerjim
new london county,ct
jd h, jd 50, jd2010,jd 790,case530hoe
i need to re-wire my trailer thats about 4yrs old. wiring is all pinched on the frame rails and shorts and grnds, i will be installing conduit and running my wire w/in it this time. i'm having some trouble finding wiring locally all the parts stores, haven't tried napa yet but will today ,they all carry a kit w/ lights included, i just need some wire for the lights and brakes and maybe a new box for my battery for the breakaway. anyone know of a good online source? thanks jim
   / trailer wiring #3
Local TSC or even a RV dealer. There you can buy it on the roll.
Chris
   / trailer wiring #4
Truck shops will probably have everything you need. At least the one in our locality does.:D
   / trailer wiring #5
I gave up on "kits" from the likes of Canadian Tire and Princess Auto. The plastic ones seem fragile, especially when very cold, least bump will break them. I bought a magnetic set and only install when ready to use.
   / trailer wiring #6
I don't use the made up wire bundles. I used stranded THHN/THWN insulated wire in the appropriate size and colors. You can get it at any electrical distributor.
Mitsubishi Mini Truck, 3cyl Gas Engine, 2WD (A52384)
Mitsubishi Mini...
Caterpillar 308E2 CR Midi Excavator (A52377)
Caterpillar 308E2...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2008 KOMATSU WA450-6 WHEEL LOADER (A51246)
2008 KOMATSU...
RYOBI 18V BRUSHLESS ELECTRIC 20" PUSH MOWRE (A51248)
RYOBI 18V...
