JB4310
Super Member
I will start a new thread here so not to hijack "brake controller" thread.
First of all I don't have any problems with either of my trailers, a 5 ton dumper and a 20 foot equipment trailer.
But with all this talk about trailer brakes and wiring etc I started looking how mine worked, I know, if it ain't broke don't fix it.
Anyway it started with the break away battery system on the equipment trailer, as far as I can tell mine does not get charged, next time it's hooked up I'll check the voltage to see if it's higher than 12 volt when the truck is connected and running, indicating it is indeed getting charged.
The reason I don't think it is, is because there is only one black wire coming off the battery and I'm pretty sure it goes straight to the break away switch, so how could it get charged?
Next is while trying to figure that out I was checking the 7 pin connectors, trying to determine where power could come from.
So this is the weird part, kind of a question and kind of just a statement. While checking my trucks 7 pin outlet I find I'm getting voltage from almost all the terminals except the running light blade at the 11 o'clock position and the ground.
Specifically as follows:
with key off, actually no key in ignition.
terminal at the 1 o'clock position, bat+ = 12.9 volts
term @ 3 o'clock, RT turn/stop light 8.9
term @ 5 o'clock, elect brakes 11.3
term @ 7 o'clock, ground 0
term @ 9 o'clock, left turn/stop light 1.3
term @ 11 o'clock, running lights .1
center terminal 3.9
with truck idling. but no lights on or brakes pressed.
term 1 o'c 14 volts
term 3 o'c 2.5
term 5 o'c 12.1
term 7 o'c 0
term 9 o'c .6
term 11 o'c .3
center term 3.9
Am I crazy, stupid or just unqualified to operate a multi meter?
How is this possible, like I said everything works the way it's supposed to, used both trailers this week lights and brakes work flawlessly. how could there be voltage at those terminals with nothing on especially the brake circuit? the only one that makes sense is the hot term reading of 12.9 with truck off and 14 when running.
I have the Drawtite Activator 2 controller.
ANY IDEAS ???
JB.
center terminal 3.9
term 1 o'c 14 volts
term 3 o'c 2.5
term 5 o'c 12.1
term 7 o'c 0
term 9 o'c .6
term 11 o'c .3
center term 3.9
ANY IDEAS ???
JB.
